buzzing hum - usb to mac
Posted: Wed Oct 17, 2012 9:43 am
by mmlczrk
Hi!
This is my first post, and I have a question.
I get a buzzing noise when I connect LPII via USB to my macintosh machine. It sounds like something grounding related, but Im not sure.
Any tips to get rid of it?
I dont like the sound of vacuum cleaners...
Please help me out!
Re: buzzing hum - usb to mac
Posted: Thu Oct 18, 2012 5:16 pm
by Sir Nose
If it is a laptop try unplugging the power supply and run on the battery.
Posted: Thu Oct 18, 2012 6:28 pm
by grapeflavor
I had the same problem as you for the longest time. I can't tell if its the Macbook or my Phatty that's causing it, but connecting to it via USB will cause a hum to come out of the Phatty's output.
The only advice I can offer is to switch to a standard MIDI/DIN plug:
instead of USB. I switched to a DIN plug and haven't gotten any noise since.
EDIT: For what it's worth, I did happen to notice that when my macbook was unplugged the noise would go away.
Posted: Sun Oct 21, 2012 2:30 pm
by mmlczrk
grapeflavor wrote:I had the same problem as you for the longest time. I can't tell if its the Macbook or my Phatty that's causing it, but connecting to it via USB will cause a hum to come out of the Phatty's output.
thank you! do you recommend any particular product or brand?
Posted: Sun Oct 21, 2012 6:59 pm
by grapeflavor
This is what I am currently using:
http://www.guitarcenter.com/Live-Wire-D ... 1166788.gc
Although, any one should work just fine.
Posted: Tue Jul 02, 2013 6:03 am
by digilog
I have this problem too.
I just got my Phatty upgraded to the full stage II specs @ the factory (+CV output mod).
When I connect it to my Mac Pro via USB, I get low hum+ hi pitched whine in my audio path.
The noise goes away if I revert to normal MIDI cables.
Has anyone noticed any MIDI performance difference between MIDI via USB and normal 5 pin DIN MIDI?
Particularly with regard to recording/playing back 14 bit automation?
Thanks.
Posted: Tue Jul 02, 2013 10:03 am
by Sir Nose
mmlczrk wrote:grapeflavor wrote:I had the same problem as you for the longest time. I can't tell if its the Macbook or my Phatty that's causing it, but connecting to it via USB will cause a hum to come out of the Phatty's output.
I used an M-audio Uno for a couple years without issue.
Posted: Tue Jul 02, 2013 10:20 am
by Amos
there's a "fix" for using USB also - requires only a small piece of tape or similar:
http://forum.moogmusic.com/viewtopic.ph ... 07#p114167
Posted: Tue Jul 02, 2013 2:07 pm
by EMwhite
Now I've seen it all : )
Seriously, I have Mesa Bass Amp that has a ground loop switch on the back; it does magical and wondrous things but I never opened it up to see what it's actually doing? Perhaps just dropping ground from some part of the circuit?
But I had a Matrix 6r that, depending on where I plugged it in was absolutely horrible. So I wired in simple switch, problem solved. Was always concerned about lightning (literally) striking and frying something; we get pretty bad thunderstorms where I live and the power quality is not very good.
In this case though, great to see a fix for so many! That thread is a good read.
Posted: Mon Jul 08, 2013 4:38 am
by digilog
UPDATE
My Phatty was plugged into a Dlink USB hub.
When I plugged it directly into the Mac Pro on the front panel the problem seemed to go away, or at least be seriously reduced.
