Slim Phatty MIDI / USB issues
Posted: Fri Sep 28, 2012 7:40 pm
Hi All,
I'm getting some pretty inconsistent behaviour from my recently purchased Slim Phatty.
At any giving moment, either the physical in/out MIDI stops working (to the point where the MIDI in/out menu items in MIDI setup doesn't even show up!) or just the MIDI output will stop working but will still receive.
I'll switch to USB - which sometimes works, or dies at some point during operation and stalls my audio/midi setup window.. or the thing with just appear offline. It's frustrating as hell and feels like a faulty MIDI processor in the synth.
Cycling the power doesn't usually work (and is a pain in the ass btw, with the power switch on the back of a rackmount... huge oversight). Forcing a factory reset sometimes helps. Updating the firmware makes it come back every time, but then it eventually dies again.
All this being said, something as ubiquitous as MIDI i/o should never ever be an issue on a piece of gear in 2012 so I can only come to the conclusion that it's a hardware problem. The same MIDI cables that are 'dead' from the slim phatty will send receive no problem to any other MIDI I have. It's not my system.
Anyone else running into this?
