Minitaur cutoff frequency does not track at 100 percent
Posted: Sat Apr 21, 2012 5:26 pm
by David Bulog
http://www.moogmusic.com/news/sound-sou ... s-minitaur
quote
Minitaur filter cutoff frequency does not track at 100 percent but this can be adjusted using a hidden parameter......enabling all sorts of wonderful ...
does anyone know what hidden parameter Gordon Reid is referring too?
Re: Minitaur cutoff frequency does not track at 100 percent
Posted: Sat Apr 21, 2012 8:13 pm
by artpunk
David, the filter keyboard tracking is controllable via midi CC #20 - the default is approximately 50% according to the manual, but it can go from 0 - 200% Also, I haven't actually used the Minitaur's software editor yet, but I believe all the other 'hidden' parameters are accessible from there.
Posted: Wed Apr 25, 2012 8:38 am
by Dogboy73
artpunk wrote:I haven't actually used the Minitaur's software editor yet, but I believe all the other 'hidden' parameters are accessible from there.
They certainly are
A good overview of the Minitaur editor in this video;
http://www.youtube.com/watch?v=NLi9Gy95cPE
You can off course use any device capable of sending MIDI CC to do the same thing. So a MIDI controller or DAW can be set-up to control the Minitaur. I'm looking forward to getting my Minitaur & creating a Lemur template for it. That's going to be a blast with some of the objects available for templates
Posted: Sat Apr 28, 2012 8:33 am
by GregAE
David Bulog wrote:Minitaur filter cutoff frequency does not track at 100 percent but this can be adjusted using a hidden parameter...
Hi David,
Artpunk is quite right - sending a MIDI CC#20 <value> command will adjust the filter tracking of the MT. Note, however, that the filter tracking adjustment does not persist if you cycle the power.
- Greg
