I can't polychain my Voyager SS with my LP stage I!
Posted: Mon Jan 09, 2012 12:48 pm
Hi Amos,
I have an LP (stage edition I, 3.1) and a Voyager Select Series (3.5)
I have been trying to poly chain them so I can have a duophonic synth. However, I don't know why but it is not working.
I tried using the Voyager as the first voice. I connected its MIDI output to the LP MIDI Input. I did set up everything as explained on the youtube video. It simply does't work. It doesn't work either if I use the LP as the firs synth.
I've tried everything, but the Voyager doesn't stop when it's supposed to. It sounds always, when I press the first key and the second one. The LP voice has been set up to be the 2nd voice and I hear it every other pressed key. However, they are not sharing patches (sounds). Even though the LP sounds every other voice, it's not working on the same patch. Both synths keep on playing on their own programmes.
Some questions that might help:
Do I have to have the same programs on both synths?
Is it possible to use the Voyager as the first synth, or I must use the LP?
Please help me on this. I can't poly chain my my jewels so I can play duophonically. Very frustrating
Thank you very much,
Max
Max
