RME issues
Posted: Fri Dec 09, 2011 6:08 am
by d s murray
Hello
I'm having a couple of problems with my RME which I hope someone can help with. I've had a look over previous posts and studied the manual but still have outstanding questions.
When I change the MIDI channel in the Master menu the setting is not saved on power off. Is that normal?
Also, changing the Master/HP Volume setting to take volume level from presets is not saved on power off.
I've got the VX-352, but I can't seem to get the TS inputs to have any effect. This is a mystery to me because everything else seems to work, ie I can use MOD2 and pot-map a modulation destination and it works...
...which leads me to my final query: I want to set up a patch with the classic combination of PWM pulse and a sawtooth wave. I thought this would be quite easy using my MP201 to generate an LFO to modulate the wave of OSC1, but when I set this up using pot mapping I can't get precisely the range I want, between square and thin pulse. Any ideas?
Best regards
D S
Re: RME issues
Posted: Fri Dec 09, 2011 8:09 am
by RL
Please make sure the boot version is the same as the system version.
You will find these informations in the MASTER menu (Software Version).
Rudi
Re: RME issues
Posted: Fri Dec 09, 2011 9:36 am
by d s murray
Hi Rudi
Yes, it had occurred to me that this might be the issue. The boot version is 3.0, the software 3.5. I was surprised that this was the case, as the unit was recently shipped.
Is it relatively easy to update the boot version?
D S
Re: RME issues
Posted: Sat Dec 10, 2011 10:34 am
by RL
Download RME version 3.5 here:
http://www.moogmusic.com/sites/default/ ... me_web.zip
First load bank B and after that the RME will ask for bank D.
