Animoog sounds only through earphones?
Posted: Thu Oct 20, 2011 3:49 am
by acaonweb
I'm sure that when I've downloaded this amazing app I could hear sounds from speakers too!!!
Every other apps works fine, but animoog, suddenly, not!!!
Maybe I've modified something in the app, but I don't know what, and I've re-downloaded app two or three times, and I've not resolved.
Any ideas? I think it's a bug, there's a way to communicate that?
Thanx in advance
F.
Re: Animoog sounds only through earphones?
Posted: Thu Oct 20, 2011 12:59 pm
by neuromodulator
This is happening for me, too. Can't get sound through speakers, only headphones.
Posted: Fri Oct 21, 2011 7:33 pm
by Marzzz
+1
Same problem here. It worked initially, but now no sound output thru speaker, only headphone jack.
Posted: Sat Oct 22, 2011 2:29 am
by scdreger
I heard this is only happening on iOS 5, is that what you are running? It happened to me and this fixed it (I either read this here or on gearslutz):
Go to settings on your iPad
change the side switch function to mute/unmute rather than rotate lock
Flip the sideswitch until it is clearly in unmute setting — you should now have sound.
You can change the switch function back to rotate lock now if you would like.
I hope this works for you guys, it fixed my issue.
Posted: Sat Oct 22, 2011 1:49 pm
by Marzzz
Yes, that did work. Thank you!
Posted: Sat Oct 29, 2011 3:10 am
by dtb200
Thanks - worked for me too (my side-lock switch is set for mute on/off anyway). Why had I not thought of it before? Prob because other apps don't behave this way, I.e. the volume button usually over-rides the mute switch.
