Page 1 of 2
Sustain Pedal
Posted: Sat Sep 24, 2011 1:48 pm
by mariusdevries
Just unpacked and set up new Voyager XL as master Midi controller in one of my studios :|
The packaging contained a lovely Moog footwsitch
Yet I see nowhere to plug in a standard Midi Sustain pedal
Am I missing something? Is there a workaround?
Re: Sustain Pedal
Posted: Sat Sep 24, 2011 2:22 pm
by RL
Use the gate ENV input for it and have fun,
Rudi
Re: Sustain Pedal
Posted: Tue Sep 27, 2011 1:10 pm
by mariusdevries
My gratitude! MdV
Re: Sustain Pedal
Posted: Mon Oct 03, 2011 5:46 pm
by psicolor
The voyager is monophonic, why does someone want to use a sustain pedal with it? Or is there a special playing technique which i don't know yet?
Re: Sustain Pedal
Posted: Sat Oct 08, 2011 6:56 pm
by diddi_jo
psicolor wrote:The voyager is monophonic, why does someone want to use a sustain pedal with it? Or is there a special playing technique which i don't know yet?
MIDI master controller will need a pedal at some point.
Re: Sustain Pedal
Posted: Sat Oct 08, 2011 11:29 pm
by Just Me
Hold notes while you play the TS and turn knobs is one reason.
Re: Sustain Pedal
Posted: Sun Oct 09, 2011 6:33 am
by psicolor
.... while the other hand is still free to play on another keyboard. Good idea! I Like it!
Re: Sustain Pedal
Posted: Tue Oct 11, 2011 9:26 pm
by drcarver
I just tried 3 different sustain pedals, and 2 expressions...I can't get it to work for some reason.
Re: Sustain Pedal
Posted: Wed Oct 12, 2011 12:01 am
by latigid on
I think you'll need a negative gate, i.e. a normally closed switch (push to break).
P.S. you can drone with the Env. gate rocker, but you probably knew that.
Re: Sustain Pedal
Posted: Wed Oct 12, 2011 10:35 am
by drcarver
^yeah....When I move the rocker to "ext" I get the legato drone, but only when the pedal is pressed. Otherwise, there is no sound.
I suppose it isn't a huge deal, but about a week after I got my Voyager, I had a session where a sustain pedal really would have come in handy (Playing another keyboard with my left hand, while doing some weird legato runs on the Moog with my right). I felt like a tool for having to ask the engineer to keep going back for me to overdub the Moog part with both hands. :D
Re: Sustain Pedal
Posted: Wed Oct 12, 2011 2:12 pm
by fyvewytches
drcarver wrote:^yeah....When I move the rocker to "ext" I get the legato drone, but only when the pedal is pressed. Otherwise, there is no sound.
check the settings in the menu.
Re: Sustain Pedal
Posted: Fri Aug 17, 2012 10:57 am
by psicolor
I like to use the voyager as a master keyboard. So I plugged a sustain pedal into the Env Gate input, turned the env gate to on/external, but the sustain pedal does not seem to change the midi out messages.
Re: Sustain Pedal
Posted: Fri Aug 17, 2012 2:37 pm
by RL
Hast du nicht die 3.6 Version? Da kannst du jeden beliebigen Controller im MASTER Menue auswählen.
Gruss,
Rudi
Re: Sustain Pedal
Posted: Fri Aug 17, 2012 3:16 pm
by thealien666
For those not speaking German, here's the French translation:
"N'avez-vous pas la version 3.6 du logiciel ? Puisque vous pouvez utiliser n'importe quel contrôleur dans le menu de sélection MASTER.
Cordialement,
Rudi"
:mrgreen:
Re: Sustain Pedal
Posted: Fri Aug 17, 2012 3:49 pm
by RL
Sorry, this was more a private message - the next time I will try to send it in Turkish :mrgreen:
