Page 1 of 2
MURF VST EDITOR! WOO WOO
Posted: Fri Jul 29, 2011 10:54 am
by nrvana8775
Awwwww yeah! I think I'll be grabbing another one now.
http://www.moogmusic.com/products/apps/ ... controller
VST MuRF Controller
MuRF_Controller is an exciting addition for any Midi MuRF owner wanting to easily control and expand its' power and capabilities from within their DAW.
Features include:
•Full automation functionality- Use your DAW’s plugin automation tools to create fully automated parameter changes on the MIDI MuRF. Every knob and every filter is now "easily" edited from the MuRF_Controller.
•Create, recall and save presets- Quickly capture and recall any amazing sound you have created on your MIDI MuRF. Once you've discovered a sound, you can easily save it within your MuRF_Controller plug-in.
• Envelope Scale- Allows you to access a time multiplier for the envelope that "stretches” or “shrinks” the duration of the envelope without changing the envelope shape. Changing the envelope time scale independent from the pattern rate provides a whole new range of sonic effects!
• LFO Rate- Directly access and control the MuRF's LFO speed
• Staccato and Triplet mode- Allows access to even more creative musical timing modes in the MIDI MuRF
Re: MURF VST EDITOR! WOO WOO
Posted: Fri Jul 29, 2011 11:08 am
by nrvana8775
Ummm, unless I'm totally missing this, they didn't include the pattern editor or playlist :oops:
I think I can create the patterns in the standalone, then open them in the vst, but it would have been nice to have the patterns/playlist controllable via midi.
Posted: Fri Jul 29, 2011 11:32 am
by ebo
no AU version?
Ebo
Posted: Fri Jul 29, 2011 12:04 pm
by Sir Nose
nrvana8775 wrote:Ummm, unless I'm totally missing this, they didn't include the pattern editor or playlist :oops:
Put the murf in trigger mode and create the patterns with a sequencer inside your daw
Posted: Fri Jul 29, 2011 12:37 pm
by nrvana8775
Ohhh :)
Edit: what is trigger mode?
Posted: Fri Jul 29, 2011 2:44 pm
by matbard
What? No Audio Units??!?!
Posted: Fri Jul 29, 2011 2:58 pm
by cliffman
Have never heard of 'trigger mode, but you've never needed anything extra with the Midi Murf to
sequence the faders with a DAW, just
read the fine manual for which MIDI note triggers which fader (there are a couple of modes, so it's like 8 faders x 3 midi notes)
and set up a sequence using those notes, big fun. No VST needed if all you want is faders on/off
Matter of fact, if you have a drum machine that outputs MIDI notes, you can sequence MM faders with that.
Big fun.
Posted: Tue Aug 02, 2011 3:43 am
by frabo
It is NOT working here for me with Ableton Live on OS X 10.6.8 !
This Plug in is only working if the plug in window is open !
(with an novation Remote controller I don't need to open the window of a plug in)
Hmmm, if I close the window, I have no midi output, no Automation ... :-(
Did I something wrong - any help ?
best,
frank
Posted: Tue Aug 02, 2011 10:42 am
by matbard
Did you manage to download it?
It still says"the site is down for mantainance" for me...
Posted: Wed Aug 03, 2011 5:42 am
by frabo
Yes, no problem to download.
should i upload or send it via pm ? - it is 4,1 mb
fb
Posted: Wed Aug 03, 2011 8:36 pm
by seank
i think you're trying to check out from the store. just download from here:
http://www.moogmusic.com/products/apps/ ... nloads-tab
Posted: Sun Aug 07, 2011 5:02 pm
by LoPhreaque
So... What about those of us running RTAS plugs on ProTools LE???
David
Posted: Thu Aug 11, 2011 3:27 pm
by noSpoonMusic
LoPhreaque wrote:So... What about those of us running RTAS plugs on ProTools LE???
David
bump
Posted: Sun Sep 11, 2011 8:53 pm
by LoPhreaque
David
Bumping again. I love my MidiMuRF and would love to have it integrated in my PT work without all the headache of inserts and midi control...
Posted: Thu Oct 20, 2011 1:36 pm
by BerlinAndBeyond
Will the AU version ever come out for this?
Would love to include this in my Logic setup.
Please !! :o
