sequencing model d with mp201
Posted: Wed May 11, 2011 7:26 pm
by Unfiltered
is it possible to use Logic to sequence a model d using the mp201?
Re: sequencing model d with mp201
Posted: Sat May 14, 2011 4:33 pm
by c7sus
It should be able to handle that.
You could probably modify preset #27 to take the incoming MIDI messages from Logic and output the corresponding CV's.
Playing a Model D using Logic or Sonar through an MP-201 would be a really great demo of the power of the 201.
Posted: Sun May 15, 2011 8:55 pm
by Unfiltered
thanks for the reply. I seem to have trouble getting a s-trig to function correctly. What settings do I need to adjust to get the gate out to s-trig to function correctly?
Posted: Sun May 15, 2011 11:41 pm
by c7sus
Maybe this will help.
http://www.synthesizers.com/gates.html
http://www.synthesizers.com/moog_trigger-convert.jpg
Apparently synth.com sells a cable for this purpose too.
http://www.synthesizers.com/cables.html Scroll to the bottom to see the cable. You might try contacting synth.com for verification this solution works for the Model D.
Posted: Sat Oct 29, 2011 9:50 pm
by Indeed
So what's up? What happened here? I'm wondering if I could do this too!
Posted: Tue Nov 01, 2011 8:16 pm
by Indeed
I've been researching is all over the web, & I'm gathering that this is not possible because an s-trig needs a higher voltage to open the envelope of the model d, and the mp201 is not equipped for this.
Am I correct in this? Amos? Anyone in the know here?
There are devices that ARE equipped for is like the doepfer mcv4, Kenton pro-solo, etc. I was hoping to sort of get 2 birds with 1 stone on this.....while I'm spending the money, why not get a piece that can work with the model d as well as the cv's of my foogers, minimoog & other synths.......
Posted: Thu Nov 03, 2011 12:57 am
by Sir Nose
If the voltage is not high enough, boost it.
