"Real panel parameter"; Why does it seem wrong?
Posted: Thu Mar 24, 2011 2:57 pm
by Syntholabo
What am I doing wrong?
If I choose 'real panel parameters' from the appropriate menu, why should any knob effect 'jerk' into position (most noticeable on filter and resonance). I'm sure you know what I mean; it is doing my head in... I want the panel to be as I see it, which is crucial for live performance. It makes me so angry when I hear that snap into position. Why is this happening?
I've tried initialising patch first, but this effect is still happening. The sound does change dramatically from any preset when I do 'real panel parameters', but I can't understand what is happening.
THanks anybody, who might care to advise.
Matthew
Re: "Real panel parameter"; Why does it seem wrong?
Posted: Fri Mar 25, 2011 9:21 am
by psicolor
"Real panel parameter" doesnt rotate your knobs, it simply sends the settings from the panel to the analog board.
For live performance i think it's good to make a compromise and select one of the following options: using presets only, which means not touching the panel during the gig, simply switching presets - OR - not using presets and only using the panel.
Posted: Fri Mar 25, 2011 2:29 pm
by Just Me
What OS? On mine with an older OS, when I go to real panel, the synth is real panel. Where ever they are set is what I get. No jumping to value, etc. The only caveat is that whatever patch select from's pot mapping and TP settings are in effect. This can lead to some unintended behaviours of the Mod buss and TP, for instance.
by The Analog Organist
It sounds like you'd like the Voyager Old School. It could never give you such a problem - at the sacrifice, of course, of memory.
Posted: Mon May 02, 2011 8:56 am
by Syntholabo
Thanks guys,
So what... the 'real panel parameters' is useless to me? Surely, you press it and get every knob setting as you see it. Why would you want it to be anything other? From there, I would like to 'send panel sound' for sysex dumps. Am I on the wrong track?
Help!
p.s.I can't say I understand pot mapping yet.
Posted: Tue May 03, 2011 1:08 pm
by GregAE
Syntholabo wrote:
p.s. I can't say I understand pot mapping yet.
For a nice intro to Pot Mapping, check out the 'On The Map' article on KnobTweak. Find it here:
KnobTweak > Files > Voyager > Pot Mapping.pdf
The article includes a dozen or so handy Pot Maps, too. Good stuff!
- Greg
Posted: Mon Jul 04, 2011 3:16 pm
by ssilk
has anybody figured out Synthlabo's issue?
I'm considering a Voyager RME myself, and I would like to be assured that this function works correctly
so: enable "Real Panel Parameters", the patch changes to reflect the current settings of the front panel knobs (with the caveats previously listed re: pot mappings etc.) - so far so good, right? and then adjusting a knob should not / does not result in any "quick jumps" or "jerks" or anything of the kind, it all acts on the patch just as you would expect it to?
Posted: Mon Jul 04, 2011 4:57 pm
by Just Me
ssilk wrote:has anybody figured out Synthlabo's issue?
Mine works just like you would suspect. I just went into the studio to try it again to make sure.
Going from a preset to RPP and the panels switch and knob positions are now active. They do not jump to any value when turned. The pot mapping from the original preset is in effect so things like the TS and the mod inputs can do wonky things. If I initialize and then go to RPP, then the mod sources are what the switch positions say they are (And if they are on PGM, then they are at the default setting as outlined in the manual.)
Posted: Mon Jul 04, 2011 9:15 pm
by ssilk
Just Me wrote:ssilk wrote:has anybody figured out Synthlabo's issue?
right on, thx for the info! maybe it all began then as a misunderstanding of how the function was meant to work, or perhaps an old operating system, or something... I'm loving my Voyager Old School, but strongly considering trading it for an RME - it hasn't left my house yet, and I just can't see myself dragging this thing around to shows
and hey! that's two boards I've run into you on in the past couple of days
I headed down last night to see if I could catch you gigging, but I either got there late (a little after 8'ish) or I was at the wrong place, cuz it looked pretty dead to me... I'll PM ya later, will try again next month!
