Will this work?? S&H
Posted: Mon Mar 07, 2011 10:06 am
I control the cutoff on MF-101 with the pitch-antenna on my theremin.
I want send the pitch-CV through sample and hold on CP-251 and set up MP-201 as a trigger.., Now, when I then adjust the cutoff(with the antenna), can I trigger the "S&H" so the cutoff stays at that exact position for as long as I want until I trigger it again?? Or is the "hold" time-limited depending on the LFO?
Havnt really used Sample and Hold before.
If this works Ill buy the CP-251...
