Rack ear screws
Posted: Tue Jan 04, 2011 5:50 pm
by twistedfrequency
Hi all. I have rack ears for my moog voyager RME ... but I cannot find the screws to attach these to the actual Moog and not sure if I can even get the same screws from a hardware shop here in the UK since I don't have a sample.
Can anybody help? I'm happy to pay for them + postage ... or if not can anybody provide a form factor or spec for the screw in case you cannot sell me them separately?
Hope someone can help - I tried the UK dealer already, but they do not have them ...
Re: Rack ear screws
Posted: Tue Jan 04, 2011 9:58 pm
by Just Me
I don't have one, but I'll bet they are either 8-32 or 10-32 X 3/8" SAE machine screws. You could just pick a sample of each thread up at a hardware store and try it. Don't force 'em in. They should thread freely. (Or e-mail Moog Tech support and ASK them.)
Re: Rack ear screws
Posted: Fri Feb 18, 2022 7:58 am
by oli@sub37
I have the same problem and are waiting for an answer from Moog Tech Support for a week now.
Does anybody have an official answer to this question? I'm especially worried about the maximum length and proper thread.
Re: Rack ear screws
Posted: Mon Feb 21, 2022 11:12 pm
by ummagumma
I don't suppose it's listed in the manual, in the specs somewhere?
Re: Rack ear screws
Posted: Mon Feb 21, 2022 11:16 pm
by ummagumma
Right at the top it says:
" 1. The Voyager’s carton contains the following:
The minimoog Voyager Rack Mount unit itself, four 10-32 rack mount screws with washers, packing materials, a power cord, this manual and a warranty registration card. Save the carton and packing materials in case you need to ship the Voyager Rack Mount."
Re: Rack ear screws
Posted: Fri Feb 25, 2022 7:43 am
by oli@sub37
Indeed, your quote can be found in the original REM manual, which I don't have and is also not found on the Moog website. In the newer (?) Manual available from the Moog website which is for both the keyboard and rack mount edition, there is this text:
Installing the RME in an Equipment Rack
The Voyager RME comes with four 10-32 x 1⁄2” oval head screws and four finish washers to be used to secure the RME in an equipment rack. The RME occupies 5 standard rack spaces (83⁄4’). The angles of the rear panel allow for standard 1⁄4” plugs to be used for audio connections when rack mounted. A right angled AC power connector is provided with the RME for installing it underneath a deep piece of rack-mounted equipment. If the piece of gear that is to be above the RME is very deep, you will find that it will be easier to make the connections to the RME’s rear panel before installing it in the rack. When installing rack- mounted gear, it is always best to install all four screws loosely before tightening any of the screws fully.
Which clearly states, that the included screws are not for mounting the rack ears to the synthesizer housing, but to secure the RME in the rack. Which makes sense because 10-32 screws are the standard size for rack screws in the U.S..
However, even if that is the correct size for the rack ear screws, it is very difficult to get screws with that dimension in Europe, since the standard for rack screws here is M6. Not even the distributor for Moog here in Switzerland can provide these. It's a bit of an unfortunate situation.
Waiting for an answer from Moog Support now since February 11.
Re: Rack ear screws
Posted: Sat Feb 26, 2022 7:03 am
by ummagumma
Ah, sorry I misread the post!
I found reference for a RME wooden handle kit, that apparently had a user manual
https://www.pdf-manuals.com/moog-wood-h ... 443-manual
Maybe there would be a clue in there, as it screws to the RME
I am just trying to be helpful
Re: Rack ear screws
Posted: Sat Feb 26, 2022 10:06 am
by oli@sub37
ummagumma wrote: Sat Feb 26, 2022 7:03 am
Thank you very much. Unfortunately I couldn’t find anything specific in that link either. It’s somehow logical: Why should Moog be specific about parts which are originally delivered with the synth or included in the kit.
If I don’t get an answer from Moog, I’ll probably take the RME to a metal shop and have them cut new threads for DIN M6 screws.
Re: Rack ear screws
Posted: Sat Feb 26, 2022 2:08 pm
by ummagumma
Maybe find a local place that sells bolts & screws, or bring it into a hardware store & test for thread fit
Re: Rack ear screws
Posted: Sat Mar 05, 2022 7:22 am
by oli@sub37
ummagumma wrote: Sat Feb 26, 2022 2:08 pm
After giving this some more thought, I remembered that I have some SKB cases for my bass gear for which I had to order additional rack screws because they seemed to be a different size than other rack screws. With that in mind, I was able to search for them in my "collection of musical screws drawers" and found a bag of them. Tried. Matched. Happy!
These are the ones I have:
https://www.thomannmusic.ch/skb_skb19ac1.htm
These here should fit as well:
https://www.thomannmusic.ch/skb_rack_screwset_24pcs.htm
The problem with rack and case manufacturers is that they don't specify the exact measurments of the rack screws but instead sell them in sets made as "parts for case model X" or the like.
In the end, these are definitely 10-32 screws, but I have to guess the threading is UNC.
So, ummagumma you were actually right, although the formulation in the manual is pretty vague about that.
Re: Rack ear screws
Posted: Mon Mar 07, 2022 9:40 am
by ummagumma
Well that is good to hear, some of the mystery is solved!!
And the info is here now, for others to find
Congrats!
