Page 1 of 3
KB Amount Glitch
Posted: Mon Oct 18, 2010 9:03 pm
by Bääx
I just made an LP patch where I'm using the filter's resonance only for tone, and was annoyed when I discovered that the 'KB Amount' won't save between about 3400 and 3740 (precision mode amount), or any higher than 3740, as every other parameter goes to 4095. The pot also skips straight from 3400 to 3740 and tops out there. I can reach the skipped parameters using the Precision Mode, but cannot save them to memory.
The main annoyance is that this small blackout area is where the 'KB Amount' would tune the filter resonance true to the keyboard, so my octave is forced to be sharp by a semitone, or flat by a semitone.
I found this glitch using OS v.2.0, and immediately upgraded to OS v.2.21 hoping it would be fixed, but to no avail.
Has anyone else found this problem, or come up with a magical fix?
Re: Keyboard Tracking Glitch
Posted: Tue Oct 19, 2010 4:16 pm
by Sir Nose
I'll check this out later tonight or tomorrow and let you know what happens on my LP?
Anyone else have this problem?
Re: KB Amount Glitch
Posted: Tue Oct 19, 2010 4:35 pm
by Bääx
Thanks - I'm eager to find out whether this is a problem with the OS or if it's just my LP.
All anyone has to do is enter Precision Mode from the main menu and then select KB Amount and crank the Filter pot all the way clockwise. If it tops out at 3738, then its an OS bug. If it goes to 4095, then something's wrong with my Phatty.
Posted: Sat Oct 23, 2010 2:54 am
by Bääx
Update:
I contacted Moog's Tech Support and Rosser Douglas promptly replied. Through a couple e-mail exchanges it seems that the problem is with my LP. He checked a few LP's at the factory, and the 'KB Amount' parameter worked fine from their filter pots.
It seems a weird problem, as this is the only parameter my filter pot and save function have problems with. It's hardly a crippling issue, so I won't ship my LP all the way to the factory to get it fixed (my warranty is expired). One day I intend to get the CV output mod done, so I'll get my 'KB Amount' taken care of at the same time. *sigh*
Posted: Sat Oct 23, 2010 4:37 am
by nikola
Bääx wrote:I just made an LP patch where I'm using the filter's resonance only for tone, and was annoyed when I discovered that the 'KB Amount' won't save between about 3400 and 3740 (precision mode amount), or any higher than 3740, as every other parameter goes to 4095. The pot also skips straight from 3400 to 3740 and tops out there. I can reach the skipped parameters using the Precision Mode, but cannot save them to memory.
hi, a have THE same problem, and i was told it is a software issue. :( so it' s not?
Posted: Sun Oct 24, 2010 1:35 am
by Bääx
Woah! Really? Well, if that's the case, then it's not just my machine. Then it is either an OS bug, or a hardware problem with a certain amount of LP's. My LP Stage II's serial number is SE04256. Perhaps there was a hardware problem with a run of LP's (maybe with a similar serial number to mine).
If anyone is reading this who could check their own LP, it would be very helpful to figure out this problem. As I mentioned above, just enter Precision Mode from the main menu and then select KB Amount and crank the Filter pot all the way clockwise. If it tops out at 3738, then its an OS bug. If it goes to 4095, then there is a hardware problem that affects at least two Phattys.
Posted: Sun Oct 24, 2010 5:19 am
by nikola
i have Stage I SE02160.
and i was told it is a OS bug which will be fixed. that was, what, 2 years ago? or 1,5.. anyway the problem is still with me
Posted: Wed Oct 27, 2010 5:58 pm
by Bääx
It MUST be a firmware bug, as I just checked the demo Phatty at my local music store, which had the same odd KB Amount behavior.
I hope this is taken care of in the soon expected OS 3.0
Posted: Thu Oct 28, 2010 4:49 pm
by Bääx
So, the latest word I've gotten from Rosser is:
"I have talked with one of our engineers, and apparently this problem can come from the DAC calibration being off. There is a chance that all three LP's that you have experienced have drifted in their calibrations. To fix this requires a multimeter and opening the LP up while it is on."
My encountering this problem happened because I've been getting deeper in to programing and patching my LP, and would not have even noticed this before. So I don't know for absolute certain if it's something that's drifted over the year and a half I've had it.
With three LP's displaying the exact same problem, at the exact same precision amounts, it would seem to be a factory calibration error of some kind rather than a random drift over time.
Posted: Thu Oct 28, 2010 8:21 pm
by narrowcaster
FWIW, mine does it too. This is a Stage I, serial SE00380, running OS 2.10S.
Posted: Fri Oct 29, 2010 12:33 am
by Bääx
narrowcaster wrote:FWIW, mine does it too. This is a Stage I, serial SE00380, running OS 2.10S.
Interesting, a Stage I as well.
Well, Amos, if you happen to read this I would be delighted to hear any opinion of yours: Calibration drift, factory calibration error, or firmware bug?
Posted: Fri Oct 29, 2010 4:22 am
by nikola
I also think it has nothing to do with time period.
Something would change over time, but it stays that way, and i'm talking from my experience ( 1,5 - 2 and values don't change)
Posted: Fri Oct 29, 2010 10:27 am
by magnet
Hi all- Just to input: I have a Tribute (serial #188), running V 1.04T. The filter amount goes all the way to 4095.
Good Luck ! :)
Posted: Fri Oct 29, 2010 11:13 am
by nikola
magnet wrote:Hi all- Just to input: I have a Tribute (serial #188), running V 1.04T. The filter amount goes all the way to 4095.
Good Luck ! :)
good for you :lol:
Posted: Fri Oct 29, 2010 12:44 pm
by Bääx
Good Luck ! :)
Is it the 'Filter Cutoff' amount or the 'KB Amount' that you mean?
The issue at hand is the 'KB Amount' as selected by the filter pot.
