Voyager BNC Lamp
Posted: Wed Oct 13, 2010 10:59 am
by monokit
recently my BNC Lamp on my Voyager broke.
http://www.musik-schmidt.de/Adam-Hall-8 ... e-BNC.html
And i am looking for a replacement with LED.
Which one will work on the Voyager and is recommendable?
Re: Voyager BNC Lamp
Posted: Wed Oct 13, 2010 11:05 am
by MC
As long as it's 12V and it's the right mating connector (BNC) it should work.
I noticed the newer Voyagers have a screw connector and not the BNC bayonet.
Posted: Thu Oct 14, 2010 2:36 am
by jadeli89
you can contact the supplier directly.. hope you could fix it as soon as possible.. good luck!!
Posted: Wed Oct 20, 2010 5:52 am
by monokit
MC wrote:As long as it's 12V and it's the right mating connector (BNC) it should work.
Ah, great, i already figured that the newer Voyagers have a TNC bayonet. Mine is an older model. I couldn´t find subsitute lamps...they look like being from a car...
Is there an alternative lamp that can be attached to the BNC connector? Something more extraordinary?
Posted: Wed Oct 20, 2010 9:29 am
by Brian G
In case anyone doesn’t know and just needs to replace the bulb, the Littlite Q 5
http://www.littlite.com/products_accessories.php
I got mine at Guitar Center.
Posted: Sat Jun 23, 2012 10:47 am
by Spav
The TNC socket is very easy to replace with a BNC then you have a choiceof many LED lights as it is fairly common on mixing desks to have a BNC light.
Posted: Fri Jun 29, 2012 7:40 am
by Spav
Even easier............
Found a TNC to BNC adapter floating around in the lab works a treat. Now the BNC LED lamp from the mixing desk fits
http://www.maplin.co.uk/tnc-plug-tobnc- ... C+Adaptors
