Long time lurker, Recent 32 buyer. SN #1820.
Can I ask a total noob question?
- when I want to power down, can I simply remove the power from the unit? There is no off sequence with the unit?
Thank you.
Thanks a bunch Mmarsh100! Will be sure to put that into practise.mmarsh100 wrote:No OFF sequence that I know of but it pays to keep two things in mind: don't turn Mom off if she's writing something and I generally turn the volume knob down before power off.
You should get a mixer.franklinstower wrote:I just bought three mother 32's and am brand new to synthesis. Just got the sub 37 a couple years ago.
I want two of the mothers (sometimes three) to act as one synth for drones in my band. Do I have to have an audio out cable coming out of both of them (or all three) into my speaker or is there another way? I don't use anything else its just straight from the mothers to the speaker.
A small Behringer mixer is inexpensive, but basically anything that can mix the three channels and give either a stereo or mono out to your powered speaker setup. I use a Behringer fx series. Has some built-in fx that are passable in a mix. You don't need to worry about fancy, just one that can accept three unbalanced cables in and give you a 1/4" out to your speaker. You can use pan settings hard to one side on all three mothers, then on output too, to get your mono mix to speaker.franklinstower wrote:Ok Ill get a mixer. I have to go with the cheapest used thing I can find for now-- is there anything I should not get or that you recommend?
Thats a nice little mixerred wrote:I would recommend this handy little box
ART Powermix III 3 STEREO Kanal mixer
I have a quadra thru. A kenton 5 thru also. Both great thru boxes. Just had to get second 12 channel mixer this year due to hardware expansion and quite a few synths with stereo outs.red wrote:It's not always the reality what a picture is suggesting![]()
- There are three MIDI cables (two red, one green) used to connect a MIDI Solutions Quadra Thru to the three Mother 32 modules
- Each AUDIO OUT is going to the IN 1 to 3 (left) of the ART Powermix. So you can pan the signal in the stereo signal...
