Page 51 of 97
Posted: Fri Mar 22, 2013 5:40 pm
by americankiwi
Thanks for the kind words everyone
...but thanks to "Kenneth" for taking the wind out of my sails!
if you had read my earlier posts you would of known that i saved the first 2 mini's i had from going to the trash heap
they were nothing more than a pile of broken parts in boxes.
i bought this 3rd one as my other mini is too screwed up to fix right now... i bought the 3rd one as a parts unit also
took the parts from #5372 and installed them in #5921.
in my view a hoarder is someone that just takes sh!t home and dumps it in a corner somewhere never to be touched again...
i dont think i fall in that category!
This is what i started with
the wood cases were too badly damaged i had to make new ones
Posted: Fri Mar 22, 2013 6:56 pm
by thealien666
Don't mind Kenneth, he's just jealous of your, now 3, gorgeous Minimoog Ds...
Having had, myself, to work on bringing my own Mini back to full health again when I bought it, from having been improperly stored for too long in an hostile environment, although evidently not as much as you, I can appreciate all the efforts you made on yours. With fantastic looking results I might add.
latest
Posted: Thu Mar 28, 2013 6:49 pm
by FlametopFred
Yamaha EX5 and EX5r
both of which will employ Moog Little Phatty Stage 2.
- EX5 keyboard can play the LP2
- EX5r can send out arpeggiator information to the LP2
I know ... sort of redundant overkill but I like to send out arpeggiator data, then flick the arpeggiator switch on the LP2. Sort of like one LFO feeding into another. Kinda.
Posted: Fri Mar 29, 2013 12:24 am
by fishman77
Got me a white Minitaur! Sounds so awesome!
Untitled by
TheSolutionMusic, on Flickr
Goes well with the various other white gear I've gotten recently.
Untitled by
Adam
http://www.thesolutionmusic.com
Posted: Sun Mar 31, 2013 1:43 pm
by fyvewytches
fishman77 wrote:Got me a white Minitaur! Sounds so awesome!
and looks sexy !!!
Posted: Sun Mar 31, 2013 4:18 pm
by Kenneth
thealien666 wrote:Don't mind Kenneth, he's just jealous of your, now 3, gorgeous Minimoog Ds...
No I'm not!!!
Well, maybe a little...
Sorry if I sounded hostile. I was just worried that you were keeping synths around for no apparent reason. I stand corrected. Thanks for bringing life back to these poor abandoned beasties.
Posted: Sun Mar 31, 2013 9:17 pm
by CZ Rider
Posted: Tue Apr 02, 2013 8:40 am
by sallyguzman
David Smyth wrote:xombiexplox wrote:I've googled those things over and over, and I still don't quite understand their purpose. I understand they manipulate sounds somehow, but what sort of things will you use them for? :O
Analog synthesizer parameters are controlled by voltages called "control voltages" in short "CV's". For example, 1volt applied to the filter CV Input on the back of your Slim Phatty will move/offset the filter cutoff frequency from it's current knob position. Likewise, 1volt applied to the Pitch CV Input on the back of your Slim Phatty will move/offset the pitch from it's current knob position.
The CP251 is simply a bunch of useful "modules" (like the modules you were looking at at synthesizers.com) in one unit. It is for processing Control Voltages to effect the end sound in your Synthesizer (like your Slim Phatty) by using it to change the values of parameters for you (much like the modulation section on the Slim Phatty).
It contains a Mixer for mixing together different control voltage waves etc. , two 'volume' knobs (attenuators) for weakening a signal, a noise source for random voltage generation, a simple Low Frequency Oscillator (like the SP modulation section's wave generator), multiples (for sending one signal to multiple locations), a lag processor (delays/slows change from one voltage to another) and sample and hold (a stepped voltage type effect). You can "patch" these sections together using cables in a modular synthesizer fashion and use the voltages to effect the sound of your analog synth.
Hope this clears it up somewhat!
Regards,
David Smyth
NZ
Thanks for the info!!...Really helped.
Posted: Thu Apr 04, 2013 1:08 pm
by lfo2vco
I have purchased one of Tom Carpenter’s fine analogue beasts, an Analogue Solutions Leipzig S.
Two VCO’s, sub oscillator, low pass ladder filter, two ADSR envelope generators, plenty of modulation options and an 8 step analogue sequencer built in.
Next purchase will be a rack and Minitaur Rack Kit I think
Posted: Sun Apr 07, 2013 6:17 am
by stiiiiiiive
I've been drooling on the Leipzig KS for a time now... Congrats!
Posted: Sun Apr 07, 2013 5:30 pm
by lfo2vco
stiiiiiiive wrote:I've been drooling on the Leipzig KS for a time now... Congrats!
Indeed the SK is a very handsome looking synth, and I can assure you that the Leipzig sounds very bit a good as it looks too.
Posted: Mon Apr 08, 2013 11:11 am
by red
da da da
[ moogerfooger trio ]
Posted: Mon Apr 08, 2013 1:38 pm
by EricK
Nice one red, that will go well with that GRP A4 (that was you wasn't it?)
Awaiting on these to hit my doorstep:
Posted: Mon Apr 08, 2013 2:19 pm
by MC
Kewl on the Clav D6. One funky board. Make sure it has new hammers and strings from clavinet.com
Posted: Mon Apr 08, 2013 2:21 pm
by red
yes! that's me... I will also use the trio as stand alone source of new sounds - or in any combination with sounds from other sources. I'm still exploring all the unheard noises in my muppet labs (... where the future is being made today)
