Page 6 of 6
Re: 1.1.0 is now here!
Posted: Thu May 14, 2015 5:34 am
by fwilleke
scottingham wrote:Try reinitializing the panel mode by pressing that button in and holding it for about 5 seconds.
Thanks for the tip. But that doesn't help at all. In fact, it makes everything worse: Initializing sets all parameters back to a default value, regardless of the knob positions. After doing that, it's very unlikely that any of the parameters is in fact what the knob position would suggest. It should work the other way round: It should set all parameters to the actual knob values. But then again, isn't that what the Panel mode should do anyway? ;-)
Posted: Fri May 15, 2015 3:01 pm
by Rufus the Dog
Not sure if this has been mentioned before … Running 1.1
On some presets when I press the button the panel changes to the preset settings… on others they panel changes do not change until I play a note.
This seems to depend on whether they are presets are ones I have made or factory set ones but not in any consistent manner that I can determine and it also depends on if I play the keyboard or not before switching to and fro between presets.
Am I going nuts?
R.
Posted: Fri May 15, 2015 4:13 pm
by _DemonDan_
Rufus the Dog wrote:Am I going nuts?
Hi Rufus,
"It's a distinct possibility."
Oh... and check to see if this is related to the above behavior:
(pg. 47)
DLAY PGM CHG
If Delay Program Change is ON, then a preset change made while a sequence is playing will be delayed until the end of the sequence. At the downbeat of the first step, it will switch to the newly selected preset. If the new preset also contains an active sequence, it should also begin playing seamlessly at this time. If DLAY PGM CHG is set to OFF (default) the preset will change instantly.
Posted: Fri May 15, 2015 4:51 pm
by Rufus the Dog
Thanks for the tip Dan but DLAY PGM CHG is off and the behaviour I am noticing is not consistent in line with this parameter being on
R.
Posted: Sat May 16, 2015 10:02 am
by oldmanfury
Handy cheat sheet for sequencer in 1.1.0
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Posted: Mon May 18, 2015 2:28 pm
by mrberger
oldmanfury, The link appears to be broken for me using either IE10 or Chrome.
Posted: Mon May 18, 2015 3:09 pm
by Rufus the Dog
