Page 4 of 11
Posted: Fri Feb 20, 2009 6:09 am
by moledog
is that a vermona DRM i see? i have the DRM and the perfourmer.....very very good stuff. not widely talked about though?
Yes it is. When combined with the Machinedrum it's pretty much unbeatable to my ears...
Posted: Mon May 11, 2009 2:20 am
by sixsinisters
electroestate wrote:Khoral wrote:
What stand do you use for the LP and Prophet?
It's a little hard to find inexpensive 2-tier stands that narrow enough for the LP without raising the height (typical x-stands) cos i sit when i play. And my hands get aching after few minutes because of the height.
I'm now using proline stand and bought the additional second tier for it (alesis ion on the bottom & LP on the top), but i have to bend the position both of the second tier bars towards the middle to get it narrower and secure them with the middle rod without screw em cos the position is kinda awkward for it to get screwed, just so it wont bend over and fall off by the weight. Takes a little time for me to adjust it though, i wonder it's gonna be hassle to take it to the gig.
Posted: Mon May 11, 2009 4:07 am
by Khoral
It a RTX keyboard stand, like this one
http://guitare.playback-europe.com/prod ... leguide_UK
I couldn't find an official site, but I suppose they're widely available.
When I bought the Prophet, I found an extension of the same brand, that fixes on top.
Posted: Mon May 11, 2009 10:55 pm
by sixsinisters
Hi, thanks for the link!
May i know the width between bars on it's lowest height, and how low can it go? also does the 2nd tier's angle adjustable?
Sorry for those questions
Posted: Tue May 12, 2009 5:41 am
by Khoral
Haha, you're welcome
I'll have to check out on the width tonight but I can already tell that the top stand's angle is indeed adjustable, in that the Prophet 08 on this pic could be higher (or lower if the Moog was flatter!)
Posted: Tue May 12, 2009 9:01 pm
by Subtronik
Once I get a Voyager my studio will be complete.... for awhile at least
You can check my music here by the way:
http://www.artistserver.com/subtronik
Posted: Fri May 15, 2009 3:11 am
by Khoral
About the RTX stand, the lowest height is 66cms, and then the width is 45cms
Posted: Fri May 15, 2009 8:04 am
by Subtronik
sixsinisters wrote:It's a little hard to find inexpensive 2-tier stands that narrow enough for the LP without raising the height (typical x-stands) cos i sit when i play. And my hands get aching after few minutes because of the height.
Simple solution is to set your stand for the exact height you're comfortable with. Then measure, cut and paint a thin piece of plywood to set on top exclusively for your phatty.
Posted: Fri May 15, 2009 11:14 am
by sixsinisters
Khoral wrote:About the RTX stand, the lowest height is 66cms, and then the width is 45cms
Wow, this going to be perfect, but hold on .. is that 66cm of height and 45cm of width a combination on one setting? or you just mentioned each narrowest and lowest? Thanks for your time.
Posted: Fri May 15, 2009 11:18 am
by sixsinisters
Been thinking about that too, but the edge holder wouldn't be able to function cos i put a little angle on it as the LP is on the 2nd tier .. hmm i guess the other solution here is to find higher chair lol
Posted: Fri May 15, 2009 12:13 pm
by Khoral
That's right, one setting
When the stand is at its lowest, you got a 45cms width with a 66cms height
Posted: Fri May 15, 2009 12:36 pm
by Voltor07
Khoral wrote:That's right, one setting
Khoral, what's the weight limit of that thing?
Posted: Fri May 15, 2009 12:47 pm
by Khoral
According to the official specs, 70kgs, which seems odd to me but there you go
At least I know it can stand a Phatty!
Posted: Fri May 15, 2009 1:05 pm
by Voltor07
Khoral wrote:According to the official specs, 70kgs, which seems odd to me but there you go
Cool, thanks! That's a lot of weight for a single braced X stand.
That's like, over 140 Lbs! 2.2 Lbs=1 Kg.
Posted: Fri May 15, 2009 1:37 pm
by Khoral
Well, I could try to climb on it, haha
