Page 4 of 7
Posted: Tue Jan 13, 2009 2:33 pm
by Carey M
rajprods wrote:Just wondering if you've had any experience with the Studio Electronics Omega 8.
I made
this little demo of basic Omega polysynth sounds I made. All dry, except for that very last bit.
- CM
Posted: Tue Jan 13, 2009 2:40 pm
by sunny pedaal
amazing, what a nice sound
Posted: Tue Jan 13, 2009 2:57 pm
by rajprods
Carey M wrote:rajprods wrote:Just wondering if you've had any experience with the Studio Electronics Omega 8.
I made
- CM
Interesting.... It seems to make a wide variety of sounds.
I just got some feedback from an Omega 8 owner. He said it's the best synth he's ever had, and nothing can come close to it. Of course, it's his opinion, but he was going to sell then realized nothing could compare to it. The price is just too out of range for me.... I would have to almost sell everything, then I would have maybe two modules! Looks like I will have to rely on the Nord Lead 2x for now. Can anyone suggest an analog type of box or filter that I could run the Nord Lead 2x through to make it sound either warmer or to make it sounded different if it's necessary? I'm not saying anyone is wrong with the sound, it's just that maybe changing the filter sound every once and a while will give me some more options.
Posted: Tue Jan 13, 2009 3:28 pm
by Voltor07
Reminds me of the old Moog modular. Is the Omega 8 analog or digital? So hard to tell over the internets. The series of tubes makes everything sound digital. Except Chuck Norris' synths.
Posted: Tue Jan 13, 2009 3:41 pm
by rajprods
Voltor07 wrote:Reminds me of the old Moog modular. Is the Omega 8 analog or digital? So hard to tell over the internets. The series of tubes makes everything sound digital. Except Chuck Norris' synths.
It's analog.
Posted: Tue Jan 13, 2009 3:49 pm
by Voltor07
And expensive, too! Geez, it costs as much as a Moog Modular!
Posted: Tue Jan 13, 2009 3:58 pm
by EricK
Yeah those Modular synths cost as much as they always did. THe Buchla 200 still costs about 30K as does a brand new System 55 from Modusonics.
Posted: Tue Jan 13, 2009 4:21 pm
by Brian G
. Can anyone suggest an analog type of box or filter that I could run the Nord Lead 2x through to make it sound either warmer or to make it sounded different if it's necessary? I'm not saying anyone is wrong with the sound, it's just that maybe changing the filter sound every once and a while will give me some more options.[/quote]
Easy, MF 101
or you can run it through the Voyager.
Posted: Tue Jan 13, 2009 4:40 pm
by rajprods
Brian G wrote:. Can anyone suggest an analog type of box or filter that I could run the Nord Lead 2x through to make it sound either warmer or to make it sounded different if it's necessary? I'm not saying anyone is wrong with the sound, it's just that maybe changing the filter sound every once and a while will give me some more options.
Easy, MF 101
or you can run it through the Voyager.[/quote]
So, you think the MF 101 will make a noticeable difference in the sound? Just trying to "warm it up" a bit and also have some options for additional filtering if necessary.
Posted: Tue Jan 13, 2009 5:06 pm
by Brian G
It's one way, there are other filters out there that will give you more options tjhough (High pass, Low Pass, Band Pass) but the MF 101 is a nice filter to have laying around. You could also try some mild Chorus and reverb on it .
Posted: Tue Jan 13, 2009 5:21 pm
by rajprods
Brian G wrote:It's one way, there are other filters out there that will give you more options tjhough (High pass, Low Pass, Band Pass) but the MF 101 is a nice filter to have laying around. You could also try some mild Chorus and reverb on it .
Can you suggest another filter with the options you mentioned?
Posted: Tue Jan 13, 2009 5:42 pm
by rajprods
I see that Studio Electronics has one with high pass, low pass, and band pass options.
http://www.studioelectronics.com/images ... ILTER.html
Posted: Tue Jan 13, 2009 7:12 pm
by Voltor07
That looks like a nice filter. I wonder how much it is, though.
Posted: Tue Jan 13, 2009 7:44 pm
by EricK
This is an electro harmonix Bi Filter. Its a dual multimode filter. Probably retails around 500 or so.
Posted: Tue Jan 13, 2009 8:59 pm
by gd
Voltor07 wrote:That looks like a nice filter. I wonder how much it is, though. :?
$479 new
Lots of good suggestions but if you want a modern poly analogue I still think that you are down to 3 main choices (how did the PolyEvolver sound to you)? The Omega8 is one fantastic synth, with the present state of the economy you may just luck out and find one used in the $2500 range. The A6 and P08 are great synths as well both capable of excellent pads, leads and basses. For strings though I opt to layer the 2 JD-990's (Vintage and Sounds of the 60/70's cards installed) with the JD-800 and a Kurzweil 2500r.
