I was thinking along those lines for quite a while and that's the kind of thing I was waiting to read. If read you correctly, the MP201 can thus be used as a midi-to-CV unit for the OS (with Pitch, Gate and mod wheel)? How about the fourth CV for mod bus 1 ?Amos wrote:I just finished implementing per-channel MIDI notes to Pitch-CV... with pitch-bend!
You can adjust the CV scale on each channel independently, to get all your stuff playing in tune... does true 14-bit pitch bend which you can set from 1-12 semitones... and it uses the CV scale per channel so all pitch bends will be in tune with each other, even across multiple VCOs that are not calibrated to each other! So, you can play an MF-102 and MF-107 oscillator via CV from a MIDI keyboard at the same time, and have them track each other, even pitch bend them both in unison! That is the idea, anyway...
Amos
The emphasis on the product so far has been as a multiple expression pedal capable of CV output, but for mainly moogerfoogers, and with some midi programing features. And this is a product in itself.
But since this thing has everything hardware and software it needs, even if it was not the initial goal of the product, it can/could also serve as a complete midi-to-CV (Moog brand) solution for vintage synths and OS. Quite an original idea to put a midi-CD circuits directly in a box with 4 expression units at the touch of a switch.
Now that would be a sizzling hot pedal. I'll take two. (and drop the Kenton or PAiA ?)
