Page 3 of 3
Re: Disabling sequencer, is it possible?
Posted: Mon Nov 07, 2016 4:06 pm
by Tonite
Hello,
Now I use this small device that let me filter midi events :
http://www.audiothingies.com/product/midibro/
Regards
Stephane
Bonus: when I do not use MidiBro to filter midi messages, I use it to generate modulation signal usable through assignable patch input.
Posted: Fri Jun 16, 2017 1:07 pm
by muleskinner
I hope this is being looked at in a firmware update.
I want to be able to slave the M32 to another sequencer's clock but not have the sequence start every time I hit 'play'!
Gonna try that single rest workaround for now...
Posted: Thu Aug 24, 2017 11:12 am
by guzao
Does anyone found a concrete solution to fix it please ?
Posted: Tue Sep 26, 2017 8:27 am
by mibolux
bichuelo wrote:rudetee wrote:I have created a empty sequence on M32 by entering a rest on step 1.Now when I start Live it does not go bongbongbong....
I did the same and it works
Well yes but it does not play your Midi notes either or?
Posted: Fri Dec 08, 2017 7:01 am
by ulverine
is there a way to disable the sequencer but still get the midi clock from ableton through the assign out on the mother?
Posted: Mon Apr 09, 2018 2:12 pm
by nolanhaener
***Simple Workaround***
Program a blank sequence in keyboard mode, by inputting the hold/rest all throughout the sequence. Length of sequence shouldn't matter, as it will now just play the sequence you have from elsewhere. Save that as your first sequence if you need to.
Hope this works!
Posted: Tue Apr 24, 2018 4:09 pm
by AndreN
If I program a blank sequence, external midi notes won´t be played as long as the sequencer with the blank sequence is running. How did you do this nolanheaner?
Posted: Sun Nov 11, 2018 7:14 am
by ello
when trying to filter start stop the arpeggiator doesnt work too. so i use the cv channel of an analog four to process the notes. i guess a midi cv converter is the only real way to go
Posted: Sat Feb 16, 2019 3:27 pm
by Lrk
Maybe if Moog would like to provide some schematics, i don't mind resolder a jumper or a switch to enable/disable this behaviour.
Posted: Mon Feb 25, 2019 8:27 am
by GilbertMason
I've indistinguishable hindrance from others. I have the Social Entropy Engine as my sequencer and i must arrangement the M32 from here, yet on the off threat that I debilitate Midi alter from the Engine, at that point I are not able to send clock messages to other rigging on that midi port.
Posted: Sun Jun 30, 2019 8:47 am
by henrikmaneuver
Did anyone ever get the blank pattern trick to work? No matter how I try the my Mother 32 is ignoring all incoming midi while playing a blank pattern. Any advice would be very helpful!
