Sub 37 pre-release Editor 0.9.25 + firmware version 1.1.13
Everything Sub.
Glynbo
Re: Sub 37 pre-release Editor 0.9.25 + firmware version 1.1.
Post by Glynbo » Fri Dec 11, 2015 11:30 am
Hi Paul_sub37, I must have my midi ins/outs setup wrongly, my editor is showing in the editor settings box at the bottom in the light grey font `soft 0.9.26 Sub27 disconnected` and my sub37 does not respond to the editor or the editor to the sub37. On the editor in the editor setting I have it set up with the midi in and out to the sub37 and KB controller to my Launchkey 61, yet it works fine in stand alone. Cheers Glyn.
paul_sub37
Post by paul_sub37 » Fri Dec 11, 2015 11:45 am
This is what it looks like in live for me:
My Sub 37 Patches - Sub 37 + Mother 32 + UR-44 + OS X 10.11/Ableton Live/Logic Pro X + Push 2
Amos
Post by Amos » Fri Dec 11, 2015 12:52 pm
Glynbo wrote:Hi Paul_sub37, I must have my midi ins/outs setup wrongly, my editor is showing in the editor settings box at the bottom in the light grey font `soft 0.9.26 Sub27 disconnected` and my sub37 does not respond to the editor or the editor to the sub37. On the editor in the editor setting I have it set up with the midi in and out to the sub37 and KB controller to my Launchkey 61, yet it works fine in stand alone. Cheers Glyn.
you might try deleting the app preferences; it will rebuild them and this can clear out some config errors.
To do this, in the editor go to the Librarian page, right-click on the Factory Presets folder (or any preset in the Preset Library section) and choose "reveal in Finder"/"reveal in Explorer" to open the preset library folder... go Up a folder or two and you'll be in the main Sub 37 Editor folder and you should see two files named "Sub37 Editor.prefs" and "Sub37 Editor Standalone.prefs". Delete these files and re-launch the plugin editor, see if it's able to connect then.
topaz
Post by topaz » Fri Dec 11, 2015 1:49 pm
What is the latest build number ?
cheers 8)
paul_sub37
Post by paul_sub37 » Fri Dec 11, 2015 2:27 pm
Amos sent out a link to 0.9.26 editor yesterday, which includes firmware 1.1.13
topaz
Post by topaz » Fri Dec 11, 2015 2:39 pm
Amos
Post by Amos » Fri Dec 11, 2015 2:43 pm
Important note for Windows users
This is mentioned in the documentation, but just in case it was overlooked...
If you are using Windows XP, 7, or 8, then the editor plug-in won't work as expected in your DAW unless you have the Moog USB MIDI driver installed and working.
A quick way to determine if the Moog USB driver is running is to look at the name of the Sub 37 MIDI ports. If the Moog driver is running, then the ports are named "Moog Sub 37 In" and "Moog Sub 37 Out". If you are using the default Windows driver, then both ports are simply named "Moog Sub 37" ( as in paul_sub37's screenshot).
The reason for this is that the default Windows driver only allows one app at a time to use the USB device, meaning either your DAW *or* the Editor plug-in, but not both at the same time (which is what you want). This is fixed in Windows 10, so you don't need the Moog USB driver on that OS, but for Win XP/7/8 you do.
DrJustice
Post by DrJustice » Fri Dec 11, 2015 2:44 pm
paul_sub37 wrote:Image
Looking good! I like that sequencer page :)
A couple of Qs:
1 - I see there are sequencer SAVE and LOAD buttons. Does this mean that sequences can be saved and loaded as separate file types, so that any sequence can be applied to any preset?
2 - Is the LED BRIGHTNESS stored in the synth itself (if so I'd think we'll see it in the GLOBAL menu eventually)?
Glynbo
Post by Glynbo » Fri Dec 11, 2015 2:45 pm
Hi Paul_sub37 and Amos, thanks for your help but I sorted it by installing the Drivers even though I am on Windows 10! It works absolutley brilliantly now thanks :P :P . Cheers Glyn.
ziggomatic
Post by ziggomatic » Fri Dec 11, 2015 2:59 pm
is there any new features and/or bug fixes in the firmware include with the editor?
lvdtsimulator
Post by lvdtsimulator » Fri Dec 11, 2015 10:23 pm
A couple of Qs:
1 - yes, just tried that and it worked.
2 - it seems to be saved in the synth, as it remembers the brightness after turning it off, as far as I can tell it's global and non patch-dependent
Sub 37, MOX8, Z-1, D-50, D-110, NS5R, DS-8, PK-5A
paul_sub37
Post by paul_sub37 » Sat Dec 12, 2015 6:43 am
DrJustice wrote:A couple of Qs:
1 - yes, it saves and loads sequences as .seq files. you can load these back into whatever preset you want.
2 - led brightness is stored in the hardware. i just tried setting it to the lowest, turning it off and disconnecting the usb cable - on powering it back on the leds remainined at their dim setting.
ziggomatic wrote:is there any new features and/or bug fixes in the firmware include with the editor?
not seen anything new in the firmware itself
DrJustice
Post by DrJustice » Sat Dec 12, 2015 12:31 pm
Thanks for the replies lvdtsimulator and paul!
Separating out the sequencer data is a very good move. Adding functionality in this manner is going to make the editor very worthwhile for me. Good job, Amos and the Team !
paul_sub37
Post by paul_sub37 » Sat Dec 12, 2015 12:36 pm
I still find it weird with this forum how posts can suddenly appear in the middle of a thread due to members with low post count having their posts moderated - makes it look like I just plain ignored lvdtsimulator's post, but it wasn't there when I posted!
milwel traamen
Post by milwel traamen » Sun Dec 13, 2015 3:44 pm
The arpegiator led doesn't dim. Is this normal?
Moog sub 37. OSX 10.11.1 I7 4,5ghz quad core 32gb ram 64bit. Cubase 8.5 pro. Motu 16A. Motu midi expres XT. Novation sl49 mkII.
