Minifooger Delay release date?
Re: Minifooger Delay release date?
Hy Fantastca,
i got one 2 and a half weeks ago,I'm in the uk to .i looked online and a shop had one, its number 046.
Sounds great, apparently the first couple hundred have the original design BBD chip before they had to change it for whatever reason.
So I'm pretty luck i guess!
pat
pat
huh?patrickwalden@me.com wrote:apparently the first couple hundred have the original design BBD chip before they had to change it for whatever reason.
pat
I saw a couple on ebay this week, are they making their way to stores yet?
sesshinnofi.bandcamp.com
soundcloud.com/no-fi-sound-system
The minifooger delays have shown up on Amazon in the last few days.
looks like guitar center is taking orders as well
Just got confirmation today that mine shipped and should be delivered tomorrow! The wait has been killing me!
LP solar, minitaur, m32, werkstatt, 101/102/103/104m/105m/107/108m,cp-251,mf delay v1&2+drivev2, microkorg, monologue, volcas, monotribe & trons, sq-1, too many pedals!, guitars, '07 imac (10.11.6), simmons sds7, & now eurocrack, etc...
Have been using mine for a week - it's everything (and more?) they said it would be
Nice. Anyone here from UK who got their MF Delay?
Moog Sub Phatty (firmware 2.1.12 beta, editor 1.1.0) | Ableton Live 9.7 | macOS Sierra 10.12.3
yeah i got mine about a month ago, serial 046.
Really a fantastic delay, i have a few and the fooger delay.
It got character and the drive knob is great for warming stuff up, been using it for reaping everything from vocal to drums..
As a guitar pedal the only thing that i would like to have on it would be a tap tempo, apart from that brilliant,
pat
pat
Patrick, I would like to know, i want to warm up some sounds like you. Is it possible to use the drive section from that pedal without the delay part of it ? I understand it has a 30ms or so at the lowest setting, is it possible to bypass the delay completely ?
How do you proceed your reamp ?
Maybe recording the output of it and moving it to the right position on my daw will do for that purpose ?
Or i will go with the minifooger drive ….
- stiiiiiiive
Dry 100% I guess.bgirl wrote:I understand it has a 30ms or so at the lowest setting, is it possible to bypass the delay completely ?
But with dry 100% i won't get the drive section either if i understand correctly ?
- stiiiiiiive
I would think it another way: at worst the drive section is effective only when the effect is engaged, whatever dry/wet mix you set. So 100% dry would allow you to get what you want.
Anyone correct me.
Anyone correct me.
when I played with the original prototype, that's how it worked. I was able to use it as a drive pedal with no delay
That's right, the manual says the drive is pre-delay and affects both the input and the delayed signal. So at 100% dry i will get what i need, so cool !
Thanks !
Thanks !
