Mini Moog D OSC gone Super High
grayedout
Re: Mini Moog D OSC gone Super High
Post by grayedout » Wed Jun 05, 2013 9:34 am
I have order some Op Amps ..
I did some checks with a scope and found there is no Waveform at all at R1, R22 @ R23 but there is as R53 , R73 and R89 same as R111 ,R130 & R145..
if I jump from R53 to R1 I get a waveform.. ? so could it be the Resistors or something before R1 not sure what happens before I can get .06 43k at maplin but they look much smaller I guess .06 is ok to use
grayedout
Post by grayedout » Wed Jun 05, 2013 10:00 am
grayedout wrote:I have order some Op Amps ..
just check with the OSC board removed and the R1 etc reads the same as the other ..
thealien666
Post by thealien666 » Wed Jun 05, 2013 12:37 pm
Waaaaaaait a minute.
Didn't you start this thread by saying that OSC 1 was "super high" in pitch, and now you're saying that there is no rectangular and triangle waveforms for OSC 1 ?????????
The only thing you should be concerned about, for now, is to make sure you have a sawtooth waveform with the scope connected at the collector leg of Q15 (Edit: rather Q3). According to your first statement, it should be of high frequency (super high pitch). The other waveforms are derived from this sawtooth.
The pitch control (by control voltage) and waveform generation are two separate sections of the oscillators.
Begin by trying to fix the super high pitch problem first, in the pitch control section. One thing at a time.
grayedout
Post by grayedout » Wed Jun 05, 2013 4:50 pm
I am trying to fix the super high OCS 1 , which stay super high and does not track keyboard or pitch wheel or master tune.
I was tracing the OSC board with a tech frend , and we found there is now waveform shouldn't at R1 etc. which are part of OSC 1 sound source so it looks like my problem is before the IC etc
Thanks all I am saying .. Not new falt
Cheers again , for anyone that is taking time to help
Best
Andy
grayedout
Post by grayedout » Thu Jun 06, 2013 2:08 am
Ok Thanks
I have a sawtooth at Q15 (which is OSC 2) but nothing at Q3 (OSC 1)
thealien666 wrote:Waaaaaaait a minute.
The only thing you should be concerned about, for now, is to make sure you have a sawtooth waveform with the scope connected at the collector leg of Q15. According to your first statement, it should be of high frequency (super high pitch). The other waveforms are derived from this sawtooth.
grayedout
Post by grayedout » Thu Jun 06, 2013 4:14 am
not sure what the High Pitched OSC 1 problem was but not there is no sound at all from OSC 1
thealien666
Post by thealien666 » Thu Jun 06, 2013 10:01 am
Dead OSC 1.
Strong suggestion: send your oscillator board to a tech for repair.
Good luck.
grayedout
Post by grayedout » Fri Jun 07, 2013 3:00 am
point taken, My friend is staying in a week a full time Tech he will look at it , but I will need part in stock so he can fix it while he is down..
If anyone know were the OSC source starts so I can track on the board that would really help ..
Just to recap :
there is no waveform at Q11 or R1
Kevin Lightner
Post by Kevin Lightner » Fri Jun 07, 2013 10:58 am
Just a note not to immediately assume it's a component.
It could also be a bad PCB connection, loose connection or any number of possible other problem(s.)
Proper troubleshooting is analyzing the schematic and theory behind operation.
Replacing parts based on a hunch is not troubleshooting.It's educated guesswork.
The difference is between paying a "tech" 2-4 hours guessing and paying someone that has enough experience to solve the problem in 30-60 minutes.
It's cheaper to pay an experienced tech $75/hr than it is to pay less to someone that might take hours locating the problem.
grayedout
Post by grayedout » Fri Jun 07, 2013 4:09 pm
Kevin Lightner wrote:Just a note not to immediately assume it's a component.
you are 100% right on this, in my case it has very little to do with money and more to do with being a hands on person. be it Oak Door's and Windows the odd synth , to date a JP8 and ARp2600.. my new thing is a MiniMoog.. and I love it. but my oldest friend is a tech so I alway have him to call and fall back on..
This Forum is new to me and I have found it a great place... I just hope I can give something back soon..
Andy
grayedout
Post by grayedout » Thu Jun 20, 2013 4:20 pm
Hi all, just an update to close this , my old friend Simon Flinn came to stay last weekend (a great tech vintage gear or not). Anyway there was not part failure he cleaned the connection from Osc card to socket with a rubber and re soldered some dry joints .. That was it
Thanks again for all your help!!
Very best
Andy
thealien666
Post by thealien666 » Fri Jun 21, 2013 11:20 am
Great! Exactly what Kevin had suspected.
Thanks for the update, and have fun with your Minimoog, Andy! :D
Alain.
Kevin Lightner
Post by Kevin Lightner » Sun Jun 23, 2013 5:44 am
thealien666 wrote:Great! Exactly what Kevin had suspected.
Alain.
It was exactly not what I didn't expect? ;-)
Glad you're making progress!
Kevin
