ok thanks dude for that and for the other sensitive informations in your post.thealien666 wrote:Only the uA726 chip, used on the later oscillator board serials 10175 and above (...) is harder to find because it has been discontinued. And no direct modern replacements seems available (to my knowledge).
Everything else has a modern equivalent readily available.
that's comforting. thank you, kevin.Kevin Lightner wrote: If a Mini is recapped, cleaned, tightened and generally kept in good condition, there's a good chance an instrument could outlast its owner.
At worst, a Mini can be repaired usually (...)
