Sub Phatty beta firmware - final bug roundup
Everything Sub.
robml
Re: Sub Phatty beta firmware - final bug roundup
Post by robml » Tue Aug 06, 2013 7:41 pm
Amos wrote:Hi Rob, your CC info is out of date... here's a new chart.
http://www.moogconnect.net/downloads/su ... v1_4_0.pdf
fast decay for filter eg is CC 117, for amp eg is 118.
CC95 now toggles "active panel" on/off... perhaps this is the source of your other confusion?
I have verified on my end that saving a preset does not change the state of any of the parameters.
thanks amos
all good now ;)
cheers
IgorCristo
Post by IgorCristo » Tue Aug 06, 2013 9:15 pm
Hi Amos!
v 1.4.0 bug:
EDITED - USER ERROR! :P
Cheers!
Moog Minimoog Voyager Performer Edition and Little Phatty Stage II | Elektron Analog Four and Analog Rytm | Mutable Instruments Ambika | Korg Minilogue
zerstorte zelle
Post by zerstorte zelle » Wed Aug 07, 2013 11:39 am
trying to download the syx file for SubPhatty_v239_1_4_0.syx but it won't save to my mac. any thoughts?
best
ZZ
Amos
Post by Amos » Wed Aug 07, 2013 12:23 pm
zerstorte zelle wrote:trying to download the syx file for SubPhatty_v239_1_4_0.syx but it won't save to my mac. any thoughts?
control+click, "save linked file as..." or equivalent, should do it :)
GLN82
Post by GLN82 » Wed Aug 07, 2013 12:23 pm
@zerstorte zelle
I had the same problem with safari..try chrome, it worked for me
HumanByDesign
Post by HumanByDesign » Wed Aug 07, 2013 12:44 pm
Mac OS 10.8.4
Logic Express 9.1.8 [64bit]
Sub P. Firmware 1.4.0
Editor ver. 1.0.2
Firmware update:
Version 1.4.0. Great! (any release notes, or no need?)
Will there be an updated manual in the future, featuring all the new improvements? (loved the addition of the Panic feature in 1.3.9)
440hz
Post by 440hz » Sun Aug 11, 2013 6:35 am
Hello,
I am new to this forum, and purchased a Sub Phatty last Friday.
Quite happy about it...
Some questions :
1. Could you tell me please if it is possible to know which firwmare version I have.
2. And also, would you recommend me to go to firmwre version 1.4.0?
3. Do you confirm that those firmware which are talked about here are not officially released because they are still work in progress? And therefore this forum is more for beta testers and developers?
Many thanks and hello from Belgium!
440Hz.
Amos
Post by Amos » Mon Aug 12, 2013 11:10 pm
440hz wrote:Hello,
Some questions :
440Hz.
Hi 440Hz!
1.) Your Sub Phatty shipped with firmware v1.0.3. The currently-installed firmware version can be viewed on the preferences page of the Sub Phatty Editor software, which should be released this week. All registered Sub Phatty owners will receive an email with download information for the Editor.
2. Yes I'd definitely recommend to update to version 1.4.0. This version has been approved for official release and will be distributed along with the Editor software. It's also shipping on all new Sub Phatty synths since this month.
3. The forum is for everyone who is interested in the instruments... some folks are more adventurous and choose to test the beta versions, and we all benefit. In future though, the more technical development discussions will probably move to a private forum. There are conversations here about music and sounds, techniques and influences, and much more. Please feel welcome to join in.
kind regards from Asheville,
Amos
ul303
Post by ul303 » Tue Aug 13, 2013 2:37 am
I have noticed some midi issues since 1.4.
Note freezing from time to time while sequenced and have to press the panic buttons.
Never happened before.
Amos
Post by Amos » Tue Aug 13, 2013 11:54 am
ul303 wrote:Hi,
Hi ul303, are you sending MIDI via USB or DIN?
I'm looking at a USB issue now (the same thing that is causing NoFutureNoCore to lose USB MIDI connection) -- if you're using USB MIDI also, it could be the same thing. If you're getting stuck notes using only DIN MIDI, then it's something else... let me know, thanks :)
ul303
Post by ul303 » Tue Aug 13, 2013 12:59 pm
Hi Amos,
I use Midi DIN for sequencing.
SP is connected as well using USB midi but it is not activated within Live (I use it only for editor in standalone mode as it does not work for me as vst as you know).
Rexington
Note priority stuck on Low 1.4.0 anyone else ?
Post by Rexington » Wed Aug 14, 2013 11:06 am
I just discovered the Global Note Priority parameter seems to be stuck on Low Note Priority setting no matter what setting you choose. Can anyone else confirm this ?
IgorCristo
Post by IgorCristo » Wed Aug 14, 2013 11:36 am
I don't get this with mine Rexington. Everything working fine here...
Rexington
Post by Rexington » Wed Aug 14, 2013 11:50 am
Is your SP loaded with current os 1.4.0 ?
Rexington
Post by Rexington » Wed Aug 14, 2013 12:21 pm
I fixed my Sub Phatty by re-loading 1.4.0. I dunno why this worked but it did :D
