Posted: Mon Oct 27, 2008 2:50 am
I think we all agree on that the fact that there is a living and direct dialogue with Moog, through Amos, is very positive. Don't think anyone ever would disagree on that one ...
Share Ideas and Pass the word
https://forum.moogmusic.com/
any info on that version ?I just got the first build of OS2 for LPTE from our programmer. He cautions me it will almost certainly have problems at this stage, and I don't know how long it will be from now until release, but this is a major step.
jimknopf wrote:
It is exactly such sharp differerences that come to my mind when visiting a place like this (similar helpful Access, DSI and others, but not many, and even among them really few in as much a direct form as Amos and the whole Moog team practise it).
Posted: Mon Nov 10, 2008 1:38 pm Post subject:
Hi gang,
Here's the latest news, so read carefully.
Operating System v2.00 for the LP Tribute Edition is almost ready. This OS update brings the arpeggiator, tap tempo, and midi sync LFO features to the LP Tribute Edition. This OS update requires a physical memory upgrade to your LP Tribute Edition, as the new 2.0 code is too big to fit on the TE's original memory chip.
We are offering a special factory upgrade deal; if you can send your LPTE to the Moog factory, we will not only upgrade the memory and install OS 2.00, we will also replace the CV sample-and-hold chips in your LP which are the source of the "high frequency intermodulation" noise that some folks have reported in the LP TE noise thread. This results in a cleaner and clearer sound and better signal-to-noise ratio. We'll do all these upgrades, as well as fully test, calibrate and tune your LP Tribute Edition, for the genuinely-low price of $75 USD.
If you are outside the USA, we can make the chips available at an extremely low price, and work with you to find a qualified technician in your region who can do the upgrades.
Also in the works:
For people who have a Tribute Edition and aren't getting the memory upgraded, for whatever reason, we are also going to release a new OS v1.04 for Tribute Edition only; This OS is basically the same as the current OS 1.03Tc, with the addition of a new "Auto" mode for the EGR Matrix. This new mode addresses the problem with scanning noise in the LPTE filter, caused by scanning the panel buttons in the Envelope section. This noise typically manifests itself as a fixed high-pitch noise that is most audible when playing low bass sounds. The current LPTE operating system has an "EGR MATRIX: ON/OFF" parameter which, when OFF, eliminates this noise, but it also prevents you from using the panel buttons in the Envelope section. Not a good compromise. The new "Auto" mode will allow you to use these panel buttons while still eliminating the scanning noise. This new EGR Matrix "Auto" mode is also included in the v2.00 OS for the Tribute Edition (described above).
Stage Edition circuit boards with blue LEDs - Voltor07 mentioned this; the idea is that one could swap out the Tribute Edition circuit boards for a new set of Stage II boards, with the Tribute Edition lighting colour scheme. Unfortunately, I don't have any new information about this... I was waiting for a price quote from one of our PCB vendors, and I have not heard back about it. I'll shake that tree again today and see if anything falls out.
OK, I think that's everything.... cheers, all!
-Amos
