Multimoog double oscillation/harmonic problem
I've got me a MultiMoog too!
I used it for all the lead solos work on my video The Last King (solos start around 3:30):
http://www.youtube.com/watch?v=Rvf4YGt1rKw
The other day I used it on something and noticed something odd going on with one of the oscillators where the pitch starts out OK then drops. The effect gets worse the low I play on the keyboard. Don't have time right now to look into it. I still need to find time to fix my MiniMoog!
John L Rice
Re: Multimoog double oscillation/harmonic problem
If anyone else has this oscillator issue (I had the exact same symptoms of OP), try and shield the power supply from the oscillator board.
My tech fitted something akin to a piece of tin foil in a plastic sheath, between the power supply (on top of the factory card label) and osc board. Very simple, but completely resolved the issue.
FYI, I did try resitting all the connectors first, but it did not solve the problem for me, hence taking it to the tech.
Great to hear it’s been solved, thanks for the tip
