Page 2 of 3
Posted: Sat Nov 22, 2008 12:38 am
by Voltor07
EricK wrote:See when they make a LP RME ill be all over that. Ill put that in the top of My rack cabinet and ill be ready for takeoff.
YES! This is most likely the reason Amos hasn't spent too much time on the forums. He's building a prototype Rack Mount Edition LP. Amos, make sure to switch the amber panel button lights with blue ones on one of those, and sign the back with the same 2 paint pens you used before.
That way, I can have a Little Phatty Rack Mount Amos Gaynes Signature Edition, or LPRMAGSE. Pronounced, "Lepermagisee"
I really want a lepermagisee. Will it be ready by Christmas, Amos?
Posted: Sun Nov 23, 2008 10:17 am
by analoghaze
EricK wrote:How do you like that dotcom/mobius sequencer?
The dotcom is very cool. It works perfectly with the Voyager and freqboxes. Wonderful addition to my studio.
That is actually a 777, same sequencer as the mobius though. It is amazingg. I am quite happy to own one.
I'm not much of a Waldorf fan though.
I love the Waldorf sound. I am fairly covered between the XT10 and Q Plus.
I dig that setup Analoghaze.
thanks.
I love my Waldorf gear quite a bit, but my Voyager will always be #1
It really depends on my mood. Granted, a Moog Voyager is unique. expecially being able to put a freqbox in the effects loop and then running it into two delays. Using the touch screen to control delay time and feedback is crazy. The Voyager is a beast!
Sometimes, I want the poly analog. The Andromeda A6 is a monster. Incredable synthesizer.
The Q Plus will always be one of my favorite synths. Plug that into one of the Kurzweil processors and then into the MuRFs and you have a dream pad machine!
The again, I can always make some crazy sequences in my Nord G2 and send the MIDI to all my synths and make some insane sounds!
Right now though, I have just my Voyager set up in some crazy wiring sceme, using the dotcom into the CP-251.
Moog!
Re: Using Two MF-101 for Stereo?
Posted: Mon Nov 24, 2008 6:26 pm
by soundxplorer
bamse wrote:Is the only way to create a stereo MF-101 with the MP-201?
Back to the original question.
You're asking about how to control two 101s at the same time?
I'm pretty sure you could simply use a Y-splitter cable from whatever CV source you are using (EP-2, etc.)
Or you could use a Multiple, as found on the CP-251.
Posted: Mon Nov 24, 2008 10:20 pm
by Voltor07
soundxplorer wrote:bamse wrote:Is the only way to create a stereo MF-101 with the MP-201?
The Y-splitter would have to be TRS to TRS and TRS, if you understand my meaning. I tried Sam Ash, they have no such animal. They have a TRS to TS and TS. That will not work, as the CV will get grounded out if you try using that connector. Radio Shack MIGHT have it, but yes. The best solution to this issue seems to be the CP-251's four way multiple. I do not believe a stereo effect is possible with a single 101, even with the mighty multipedal.
Posted: Mon Nov 24, 2008 11:49 pm
by EricK
Analogue Haze,
Isn't the A6 midi? Use the voyager to slave the A6 and then run it back into the voyagers filters for a hybrid polysynth.
hehe
Im sure you have already.
Posted: Wed Nov 26, 2008 5:11 am
by Voltor07
analoghaze wrote:
Voltor07 wrote:I'm not much of a Waldorf fan though.
I never said I didn't like the sound...I love the sound, as well! Just not the wheel lags and sketchy control. If I could have the Waldorf sound without the sketchy control, it would be awesome! Hence, me wanting the Microwave for my studio.
Posted: Wed Nov 26, 2008 5:47 pm
by kingfriday
Voltor, I have a microwave XT and an LP and they are just lovely together. Assigning the the LP's mod wheel to any parameter on the XT seems to feel OK to me. It's MIDI, so I suppose there could be some perceived lag, but it's plenty quick for me.
Really, the XT is a mad science machine.
It lets you use all sorts of operations to modify the internal control signals. It has an 8 stage, loopable envelope and so many awesome ways to shape the modulation signals. I rarely need to make super accurate control movements because I can create so much animation just by programming it.
The sound is very unique as well. I have a Virus TI, and while the wavetables are more flexible, complex and generally "better" sounding, they don't have that glitched out, fizzy, crunchy, awful harsh awesomeness that only the XT can provide. I almost sold it to buy the LP and I am SOOO glad that I didn't.
Wow, totally off topic with all the Waldorf chat.. OK, so on the subject of stereo MF-101s- I would like to experience this, for sure. I did try something similar using my LP and single MF-101. Basically, I use the audio in on the LP, use its filter and then modulate its cutoff with the Env Out on the 101 to get the other filter. I set up the filter on the LP to sound as close to the 101's as I could. I know that technically they are both Moog ladder filters, but they sound very different. The LP is a little grimier, in my opinion, with the 101 having a wetter, juicier sound. Regardless, with no overload or drive you just have to tweak the resonance to get them sounding close. Subtle offsets of the parameters between the filter units give it a really cool sound and stereo image.
idea: use a 107's Env Follower to track drum pattern (or something rhythmic), multiply the env out with a CP-251 and use that to control the filters. S&H that CV for stepped stereo moog filtering.
God I love this stuff!
Posted: Wed Nov 26, 2008 7:21 pm
by Voltor07
Kingfriday, thanks for all that. Great info!
EDIT: The lag I was referring to can be found on the Waldorf keyboard models, not the rack mount stuff. Which is why I'd rather go with a Waldorf Microwave for my studio. On a keyboard, you'd expect the controls to respond in real time, not half a second later. MIDI lag I can deal with. I'd expect some lag on MIDI. But not on the actual hardware. That's just cheap.
Posted: Thu Nov 27, 2008 4:44 am
by analoghaze
EricK wrote:Analogue Haze,
hehe
The A6 is MIDI and CV. (same with the Voyager)
I have done that, it is a sweet combo.
I used my A6 this evening and it really is an amazing piece of equipment.
Yea.. this thread went "sideways" for a bit. In the end..... we are all here for the love of synthesis... no matter the brand.... this is our tiny corner.
We all share the love of Moog Music, but I'll talk synthesizers with anyone!
]Cheers everyone!!!!
Happy ThanksgivingQ!@!!
It is late on a Wednesday and I a "little" buzzed up!!
enjoy your synths and have a good feast.
Peace on Earth and Good Will towards Men.
Posted: Thu Nov 27, 2008 7:50 pm
by Voltor07
analoghaze wrote:
kingfriday wrote:Wow, totally off topic with all the Waldorf chat..
There's not a single thread on this forum that hasn't gone sideways. Usually, it's all related to subtractive synthesis, but on occasion, the thread gets completely derailed, and nothing can revive it.
The last bit of my signature comes to mind.
Posted: Fri Nov 28, 2008 12:06 am
by hieronymous
You say that like it's a good thing. Thread drift gets old in my opinion, especially if the original poster's question gets completely ignored.
Posted: Fri Nov 28, 2008 3:16 pm
by DeFrag
2nd that
Posted: Fri Nov 28, 2008 5:09 pm
by analoghaze
hieronymous wrote:You say that like it's a good thing. Thread drift gets old in my opinion, especially if the original poster's question gets completely ignored.
This post would be so much more worthwile if the person who posted it would have had some positive input/suggestions on the original question.
Posted: Fri Nov 28, 2008 7:22 pm
by EricK
I wonder if thread drift is anything like Oscillator drift. Perhaps a calibration of posting frequency is in order. lol
(Sorry)
But I was thinking about this the other night and I started to post. I wonder what the difference would be if you had 2 101s going to 2 different amps, or if you just used the Voyagers filters to a PA system.
WHat exactly is the difference between the 101 and the Voyagers dualing filters?
Something that I think woudl be interesting is lets think about the Moog 55. I have been advocating for a cp251 style VCA (with 4 channel audio mixer)/2 Envelope Generators /Dual Trigger Delay/Envelope FOllower (MOdules 911, 911a 912). Now if we had a trigger delay, then if we had 2 MF101's then with a single sweep of a multiplied pedal, it would create an effect very similar to the SPACING control on the Voyager.
I don't know how easy it would be, or if they would have a stereo effect but I think that this could be a solution to the original posters problem.
A dual trigger delay module like that found on the Moog 55 or better yet, just make the cp251 style unit that would essentially provide us with the advanced modular synthesis capabillity.
Posted: Fri Nov 28, 2008 7:27 pm
by Voltor07
Or, use a third-party dual trigger delay module! Great idea, EricK!
