My delay is acting up again
Scott Rolf
Post by Scott Rolf » Mon Nov 17, 2008 6:37 pm
Bryan T wrote:
Alien8 wrote:Kind of on topic, do you use the loop in the delay? Could that somehow be related?
Sometimes, but not all the time. The problem happens with and without the loop engaged. I shipped it back to Moog this morning. Amos has been very accommodating, so I'm sure things will turn out well.
Bryan
Did you tell them that you snipped the pins? I don't know if they'll give you a hard time about that or not.....
Rael Imperial Aerosol Kid
Bryan T
Post by Bryan T » Mon Nov 17, 2008 6:43 pm
latigid on wrote:For all of your troubles, they might consider just giving you a new pedal? It's not like you've kicked it around the stage is it?
Based on e-mail with Amos, if the problem isn't something obvious, then I might get a replacement delay. It might cost me a bit for a new housing, but we'll see.
Moog gave me the go-ahead (and instructions) to snip the pins, so I don't think it'll be an issue.
Bryan
totalrejekt
Post by totalrejekt » Wed Nov 19, 2008 5:19 pm
well I dropped my 104z and was for sure it would start acting up again. 2 gigs and countless times using with no problems! I hope yours gets fixed.
Bryan T
Post by Bryan T » Tue Dec 16, 2008 8:05 pm
I got my delay back from Moog today. They reused my housing, but everything else is new. Knock on wood (the side panels, perhaps?), but everything seems to work as it should.
Bryan
