Page 2 of 5
Posted: Sat May 24, 2008 1:57 pm
by jgirv
obviously if you have the LP SE and you upgrade to the new OS, you could save your original factory patches through the librarian software... but, if, like myself, you're starting out with a Stage II, is there any way to get the Stage One factory set... I have found the factory presets an excellent way to study the signal path, as well as many of them being quite usable as starting points for original patches...and would like to be able to check out the prevous set.... thanks for any reply! - jgirv
Posted: Sat May 24, 2008 2:16 pm
by Ghost
jgirv wrote:obviously if you have the LP SE and you upgrade to the new OS, you could save your original factory patches through the librarian software... but, if, like myself, you're starting out with a Stage II, is there any way to get the Stage One factory set... I have found the factory presets an excellent way to study the signal path, as well as many of them being quite usable as starting points for original patches...and would like to be able to check out the prevous set.... thanks for any reply! - jgirv
You can grab the SE factory set from the Moog website here: http://moogmusic.com/software/LP_SE_factorysounds.zip
Posted: Sat May 24, 2008 4:47 pm
by tangent uk
check this thread out on how to upload/download presets to and from the phatty,using freeware midiox.
see post by dave500
http://moogmusic.com/forum/viewtopic.ph ... c&start=15
Posted: Sat May 24, 2008 5:07 pm
by Zorn
The update for me wasn't very smooth...
I have a Mac, for the dump I used Sysex Librarian and an Edirol UM-550 midi interface...
The first time I tried to update to 2.0 I got the message FIRMWARE SX ERROR CODE 2... ...panic...
Then I tried again and... success! I did it!
The arpeggiator is awesome!
It feels a little strange playing chords on my LP though...
Posted: Sat May 24, 2008 7:28 pm
by HB3
It does feel weird.....and sounds great. Thanks to all.
Posted: Sat May 24, 2008 9:00 pm
by Little John
It all went smooth for me !
Just scatching the surface of the new OS,the arp is awesome very happy
Thanks MOOG
Posted: Sun May 25, 2008 11:19 am
by hossegor
hmmm the upgrade went smoothly, for some reason i cannot start the ARP........
setting ARP enable = on
Clock source = INT
Posted: Sun May 25, 2008 11:38 am
by Amos
hossegor wrote:hmmm the upgrade went smoothly, for some reason i cannot start the ARP........
Clock source = INT
OK, now go back to Preset mode and press in on the Value knob. :cool:
OS updated!
Posted: Sun May 25, 2008 2:06 pm
by bgm
Install went perfect, can't see any problems so far.
And the Arpeggiator kicks about ten different kinds of ass.
I could stay down here in the basement and play with it forever but it's beautiful out and the kids want to go for a bike ride so I must tear myself away for now.
Thanks again Amos and all involved at Moog.
Here's my report on how the update went
Posted: Sun May 25, 2008 4:00 pm
by llamastorm
I emailed this in, but here's what happened to me so others can read...
Hi Amos,
I encountered a problem during the update which I managed to work
around, but I thought I should share with you.
I have an Edirol UM-1 MIDI interface (switch set to Advanced Driver to
use the Edirol driver -- for which I have the latest drivers
installed), and ran the updater for Mac and followed instructions.
The UM-1 interface flashed the device and at Stage 1 reads
STAGE 1 ERROR
CYCLE POWER
Upon cycling power, it reads
SEND FIRMWARE SYSEX
At which point I can do the same again and I get the same message.
If I switch the MIDI interface to the non-advanced driver setting, I
get the same problem at the same point.
I managed to set things right by using the SysEx update method in
SysEx Librarian. (It's an Intel Mac -- 10.4.11)
Thanks very much for the update -- hopefully the above info proves useful.
(I'm glad it's not bricked!)
Posted: Sun May 25, 2008 4:11 pm
by llamastorm
I should add this is very very neat stuff though :)
Very nice to have the arp as it takes all the patches to a whole 'nother level!
Thanks!!!
Posted: Sun May 25, 2008 4:12 pm
by Tangsonghe
Llamastorm, I had exactly the same problem. Same errors
and same way of fixing it. I have since found out that
I was using a plug with a dodgy ground (after updating
my knob values were moving around), but I'm not
sure if that's why the OS updater didn't work. Glad
you got there in the end.
Posted: Sun May 25, 2008 4:18 pm
by llamastorm
I see you had an Edirol too. I posted a thread a while earlier about having some issues with that Midi interface in Logic, it might just be sketchy in general, I don't know.
Anyhow, it's rocking now.
Posted: Sun May 25, 2008 4:43 pm
by Amos
Guys: I think there may be some sort of issue with the Edirol Midi interface; something to do with "active sensing" being on. We are working on how to ensure this is disabled during the firmware transfer. Until then, I am glad the workaround is working. For Windows users who are having similar problems, I will post a link (in the first post of this thread) to a DOS-based firmware updater which should work better with respect to these sorts of errors.
Thanks for all the good info!
-Amos
Posted: Sun May 25, 2008 4:49 pm
by llamastorm
You might be able to do a Linux Live CD based on LiveCD-creator and get away from having to deal with DOS (being it's ancient and busted). That would be bootable on either Windows or Linux machines and work the same on both (without having to install any software on them).
Yum install "livecd-creator" if you are using Fedora.
I'm not sure how standard all the USB MIDI stuff is, but I think it would be fairly standard.
That may be a wild goose chase, but I thought I'd throw the idea out there.
