Page 2 of 2
Posted: Thu Apr 24, 2008 11:37 pm
by linearnorth
I'm also having this problem with my SD. Thanks for the info.
Posted: Fri Apr 25, 2008 4:04 pm
by Bryan T
linearnorth wrote:I'm also having this problem with my SD. Thanks for the info.
I hope you get your SD sorted out. Mine is being worked on at Moog right now. When I sent it in it wouldn't do a single repeat, but now that it is there it works fine. I hate intermittent problems!
Bryan
Posted: Thu May 01, 2008 10:46 am
by buzzlegs
I too, have just started having problems like this on my SD delay :-(
Posted: Fri May 16, 2008 2:03 am
by prize
is this going to be a problem for all MF-104SDs ?
can we get an official response on this as and I would prefer a preemptive fix if its a problem across the board.
Posted: Mon May 19, 2008 5:21 pm
by linearnorth
I switched the SD power supply with the one from the phaser and it works fine so far.
Posted: Mon May 19, 2008 6:57 pm
by Maskin
linearnorth wrote:I switched the SD power supply with the one from the phaser and it works fine so far.
I did the exact same thing on my 104Z on stage some weeks ago when I discovered it sounded dull, it worked perfect after switching. :)
Funny part is that I have the original power supply attached again and it still works perfect.
Posted: Mon May 19, 2008 9:56 pm
by matt the fiddler
I figured out what is wrong!
you need to send my your 104sd, and I will send you a 104z that works :)
Posted: Wed May 21, 2008 9:50 am
by Bryan T
Another update: I received my delay back from Moog yesterday (I should have had it last week, but UPS is completely incompetent). Ryan at Moog replaced the 'guts' and everything is working as it should. Great service from Moog.
Bryan
