I recorded it, so take a listen. It's factory presets.
a) Voyager dry
b) Voyager with MF Boost (max boost wo. expr. pedal)
c) Voyager headphone out trick
Roughly volume compensated, first time all dry. Then a second time with a bit processing (all processing the same, which is not perfect as processing would change when the sound gets heavier, anyway for comparison ...).
Here's the sound file:
http://pumpingalien.com/mfboost.wav
Interpretation:
- Headphone trick gives more bite but reduces sound quality (which might be desired)
(Tried to keep the gain same, but ended up with a bit more gain, difficult to dial maybe)
- Driving wo. headphone loopback and an ext. amp (MF Boost) seems to produce cleaner results, esp. on the transients
A note to the headphone out trick:
Do not use a tr cable, do not use a trs cable, both would shorten R and L. Use a Y cable and connect trs to headphone out and one tr to ext in, isolate the other th. That's the only way that would not shorten R and L, which would lead to R and L amp drivers fight against each other.
