Sub37 PITCH AMT pot range
Everything Sub.
_DemonDan_
Re: Sub37 PITCH AMT pot range
Post by _DemonDan_ » Fri Oct 07, 2016 1:56 pm
taylor12k wrote:The difficulty in dialing in subtle pitch vibrato with MOD 2. the CNTRL#4 trick works (i have mine set at 85%), but a global scale parameter or just a tweak in firmware might be a nicer solution.
Hi taylor12k,
The problem with a GLOBAL parameter to change PITCH AMT Range is that, if you set your own value, none of the Presets made by others will sound right on your Sub 37.
And similarly, if you make Presets with a non-default value for a GLOBAL PITCH AMT Range, then none of your Presets will sound right on any Sub 37s that are not also set to your chosen GLOBAL PITCH AMT Range.
