If he meant all notes off/midi panic then yes it is. And for some reason I need it often with the 37!ebowen4221 wrote:I believe both octave keys pressed together is your panic button.Waza wrote:a panic Button as well
Moog, what's next to develop for the Sub37?...
Re: Moog, what's next to develop for the Sub37?...
As others have mentioned parameter value displays. Even more significantly I would love to be able to see all tempo related variables on the panel at one time. The Arp, LFO1 and LFO2 rate displayed together in BPM (or switchable to millisecs for others) in realtime would be very useful to me.
- stiiiiiiive
Is there any way to tap in tempo for LFOs and arp/sequencer?
to tap the tempo hold the sync button on the arp for a second .... then press 3 or more times at your tempo. You would need to sync the lfos' to the arp speed
Couldn't you set one of your lfo's as a reverse ramp or square wave or to one of the envelope attacks, and have it modulate OSC1 level?UncleToad wrote:It's probably fixed in the hardware design but it is a real pity that both VCOs get routed through the mixer and filter sections into a single envelope shaper.
It would have been nice for for each VCO to have its own volume envelope. So you could then have a short blip on one VCO followed by a longer pad type sound coming from the second VCO. Of course, being greedy, it would have been nicer for each VCO to get its own filter too !
Paul
- stiiiiiiive
Thanks mateDaveBee wrote:to tap the tempo hold the sync button on the arp for a second .... then press 3 or more times at your tempo. You would need to sync the lfos' to the arp speed
That's why it's paraphonic.UncleToad wrote:It's probably fixed in the hardware design but it is a real pity that both VCOs get routed through the mixer and filter sections into a single envelope shaper.
Paul
If they had separate envelopes for each voice, it would be true duophonic.
Best regards, Ruslan Tagirov.
Toyz: MBPro+Live 9.x+LogicProX, Moog: LP StageII/Sub37/Grandmother/MF-104m/MG-105m, Nord: Stage2 SW73/ModularG2Engine, Roland: MC909/TR-8, Korg: MS-20, R-3, OTO: Bisquit/BIM, etc.
Yeah I don't get why people complain about this. It is essentially a MONO synth, with the added ability to hijack the pitch of one osc in 'duo mode' with the pitch/freq selected by key press rather than turning a freq knob fast and accurately each time to do it manuallytagirov wrote:That's why it's paraphonic.UncleToad wrote:It's probably fixed in the hardware design but it is a real pity that both VCOs get routed through the mixer and filter sections into a single envelope shaper.
Paul
And I can't say i've EVER yearned for a 2 note (full) poly synth of any description, and in the case of the 37 doing that would cause quite the price increase! If they were doing poly they may as well go 6 note poly or not bother.
This, I yearn for this:And I can't say i've EVER yearned for a 2 note (full) poly synth of any description,
To add your own preset category and name it.
Computer: 3.4ghz i7 Quad core, 24gb Ram,
OS: Windows 7 Ultimate 64 bit
Soundcard : Focusrite Saffire 56
DAW: Studio One 64 Bit
Plugins : Too Many to say
Hardware: Moog Model D, Access Virus Ti2 Keyboard
It would be a vary difficult choice for me a Voyager or the new TVP. I'm as much of a Moog fanboy as the rest...but my SEM patch is special. The Oberheim's are more limited then Moogs in a lot of ways but they sound great at what they do.
Extended keyboard length.
I yearn for this:
I'd like to see Sub64 and Sub73 models with more than just extended keyboards, but extended sequencer functions (more lights in more rows), multiple MIDI Outs and overall set-up to be an awesome controller in addition to its mono-synth awesomeness.EricK wrote:Extended keyboard length.
Just a Sub XL $2,300.00.
