You can filter out unwanted MIDI output with the Sub 37 OUT FILTERS menu settings.stiiiiiiive wrote:Uh uh... I'm not using MIDI often enough. I just forgot the Sib37 would control the parameters of the Little Phatty. You don't want that: you want only pitch and note on/off messages to go through (like a CV pitch and GATE couple, if you will).
Ideally, you should filter other MIDI messages than those ones.
Anyone, a better idea?
Third Osc for Sub 37
- Bald Eagle
Re: Third Osc for Sub 37
More on the Werkstatt as third oscillator: the VCO on the Werkstatt sounds REALLY GOOD! In fact, I have a few patches with the internal VCO's muted, just using the Werkstatt.
Can you not use the VCO in the MF-107 as a 3rd Osc?
The MF-107 can be picked up fairly reasonably compared to other moogerfoogers.
The Werkstatt is $349.00 list, so it's pretty inexpensive. Adding the MINICV costs about 30 euros and maybe an hour total time. That's pretty cheap too! So for about the same money as a 107 you can get a complete desktop synth with lots of IO.
HOWEVER, the 107 is pretty cool, too. The only way I see to control it from the 37 is with a MIDI to CV box in between. I wonder if you could hardwire a MINICV into it, tho?
*EDITED FOR SPELLING
