Stuka wrote:** Using the Editor simultaneously with a USB MIDI controller **
UPDATED 10 Feb 13
Using "MIDI-OX" and "LoopBE" (both freeware), the Editor and a USB MIDI controller can access the Minitaur simultaneously over USB
(I'm using the combination on a Windows 7 64-bit PC):
To start, make sure LoopBE (or similar virtual MIDI driver) is active (a LoopBE icon should be visible in the Windows system tray)
MIDI-OX setup:
1.) Be sure the "Pass SysEx" option is enabled
2.) Enable your USB MIDI controller and LoopBE as INPUT ports in MIDI-OX.
(Do
NOT enable Moog Minitaur as an INPUT port!!)
3.) Enable LoopBE and Moog Minitaur as OUTPUT ports.
4.) Route the USB MIDI controller INPUT port to the LoopBE OUTPUT port
5.) Route the LoopBE INPUT port to the Moog Minitaur OUTPUT port
5.) Be sure to leave MIDI-OX running! (minimized is OK)
Minitaur Editor -
"Under the Hood", MIDI SETUP:
1.) Set INPUTS to Moog Minitaur
2.) Set OUTPUTS to LoopBE (or whatever virtual MIDI driver you are using)
NOTE:
If the "firmware version: " doesn't change from "?" to "2.0.0", try clicking the OUTPUT port you previously selected, then the INPUT port you previously selected. If problems continue, you may need to cycle the Minitaur power, then restart MIDI-OX and the Editor.
You can save the MIDI-OX settings as a profile, which can easily be recalled on next use with just a couple of mouse clicks; just be sure the Minitaur and USB controller are connected before launching MIDI-OX. The Minitaur will retain its last MIDI port selections, so getting the Editor / USB controller combination working again should be a breeze!!
Works great!
