Signature Edition Voyager from 2002 serial number in the low 100s - zero problems.
Wow it's been ten years
problems with your Voyager, or not?
Re: problems with your Voyager, or not?
interesting! thanks for chiming in, those that have thus far!
The only problem I've had (had my Voyager Select for about 5 months) was there straight out of the box, but is really not a big deal - the instrument backlight pot does not dim the back lighting to 'off' just low illumination - as I said, no biggy and has no affect on it's awesome sonic character whatsoever!
Cameron
"Information is not knowledge.
Knowledge is not wisdom.
Wisdom is not truth.
Truth is not beauty.
Beauty is not love.
Love is not music.
Music is THE BEST."
— Frank Zappa
Cameron
Beauty is not love.
Love is not music.
Music is THE BEST."
— Frank Zappa
Purchased a Voyager Select series about a year ago, didn't use it that much when I first got it, noticed that the right channel was a bit softer than the left. Turned it on the other day, now the right channel only plays a strange static noise, the Highpass filter no longer works (when enabled, sound is disabled completely), and the Oscillator 3 ON/OFF switch reports a change, however does not stop the audio. Maybe I didn't use it enough? Not overly sure what to do next!
- thealien666
Sorry to hear about that.alpharisc wrote:Purchased a Voyager Select series about a year ago, didn't use it that much when I first got it, noticed that the right channel was a bit softer than the left. Turned it on the other day, now the right channel only plays a strange static noise, the Highpass filter no longer works (when enabled, sound is disabled completely), and the Oscillator 3 ON/OFF switch reports a change, however does not stop the audio. Maybe I didn't use it enough? Not overly sure what to do next!
Sounds like a couple of chips have gone bad, unfortunately. I would contact Moog support about it, either through email or telephone.
It most likely has, I have contacted the local distributor who is who I got it off, hopefully they can sort it out without a massive bill to go with it.
