Page 9 of 15
Posted: Sun Jan 24, 2010 5:47 am
by Assar
CTRLSHFT wrote:anoteoftruth wrote:Oh I love the idea of a limited edition of reversed keys. They'd be rad.
Sounds like a relatively easy factory mod to offer.
Sounds like a very expensive mod to offer, considering the number of buyers that would be willing to pay for it ... I guess.
Posted: Mon Jan 25, 2010 1:36 am
by jgirv
...very true.. the organ builders most often "cut their own" out of the stock wood, then apply the veneer tops... it's a work of art, to be sure. They last forever and age nicely...
Posted: Mon Jan 25, 2010 2:27 pm
by CTRLSHFT
Assar wrote:CTRLSHFT wrote:anoteoftruth wrote:Oh I love the idea of a limited edition of reversed keys. They'd be rad.
Maybe not cheap, but I imagine if they can get a reliable source for the inverted boards swapping them out with the existing one might not be all that tough, maybe an hour of work. ::shrug::
Posted: Tue Jan 26, 2010 5:57 pm
by Chris Rimby
Maskin wrote:Not sure if this is mentioned before (I suppose it has) but I would be happy with voice expanders in 1U rack format instead of a new version of the Little Phatty. I own 2 LPs but there's no way I would buy 6 more to have 8 voice polyphony. I probably would buy 6 voice expanders.
Absolutely. I really, really hope this happens.
Posted: Mon Feb 08, 2010 9:19 am
by Sir Nose
Woot woot!!!!
Another idea for LP improvement. Reading through the thread now, some of my ideas were okay some were eahhh so-so at best. I think this one would be hot. It should be possible through softwear and could open up the LP to an area of sound that it has not been super well suited, pads.
Patch morph. Set the destination patch and the amount of time/ beats for the transition to occur and all the parameters would slowly change from one patch to another. I'm not sure if the processor could handle all parameters at once so maybe it would require some settings to be the same on both the source and the destination patch.
edit: If the computer based patch editor could generate a midi sequence of CCs to drop into a sequencer to create the morph, that would be almost as nice. And I might even buy it then.
Posted: Mon Feb 08, 2010 10:40 am
by mayidunk
Sir Nose wrote:Woot woot!!!!
And with that, have the capability to morph back and forth between patches using the mod wheel!
Posted: Mon Feb 08, 2010 4:52 pm
by CTRLSHFT
Really cool idea!
Posted: Tue Feb 09, 2010 6:10 am
by superd2112
lovedroid wrote:Aftertouch!
+ a 2nd modulation slot to be able to use the aftertouch to anything...
This pretty much sums it up for me as well. A second LFO is my main wish, and aftertouch is a close second. Add a 3rd oscillator, and you would have a machine which would come very close to the Voyager's sonics, while still being lighter, more portable and more affordable.
Posted: Tue Feb 09, 2010 6:23 am
by jamezdd73
This was sort of mentioned in the Taurus forum...
But being able to split the keyboard, so that one section plays the LP normally, and the other sends midi out. And you can choose where the split point is.
Posted: Wed Feb 10, 2010 3:06 pm
by Voltor07
This would be amazing!
Also, being able to split the keyboard so part of it sends MIDI would be most useful...for those who use MIDI extensively.
Posted: Thu Feb 11, 2010 6:24 am
by tyrannosaurus mark
jamezdd73 wrote:This was sort of mentioned in the Taurus forum...
Would love this!
Posted: Thu Feb 11, 2010 4:44 pm
by CTRLSHFT
Here's a wacky thought:
Being able to split the KB to play different patches between the two splits.
Like psuedo-bi-timbral action!
I think they'd probably need a faster chip in the LP somewhere to be able to handle switching between the two at any decent tempo, but could be fun.
Otherwise, they could make a Polyanalog and give us bitimbrality that way.
Posted: Fri Feb 12, 2010 9:12 am
Try playing and switching through presets really quick, it creates weird (and sometimes cool) artifacts, I imagine that's what would happen if they tried to implement that
Posted: Fri Feb 12, 2010 11:08 pm
by CTRLSHFT
tyrannosaurus mark wrote:Try playing and switching through presets really quick, it creates weird (and sometimes cool) artifacts, I imagine that's what would happen if they tried to implement that
I gave my LP a minor heart attack doing that the other day, froze up for 30 seconds or so before it'd refresh to the new patch from cruising through others.
I could do this more slowly and time compress accordingly through, could be fun...
Posted: Mon Feb 15, 2010 10:48 am
by _DemonDan_
CTRLSHFT wrote:I gave my LP a minor heart attack doing that the other day, froze up for 30 seconds
Hi CTRLSHFT,
It's possible that the freezing you experienced was do to an issue with the LP's current OS.
If you scroll too quickly past a patch that uses LFO as the Arp Clock you'll freeze (as described).
The fix is to change those patches to use something other than LFO for the Arp's Clock.
I think this is most or all of the patches that do so:
4, 6, 11, 14, 18, 33, 40, 44, 46, 66, 82.
I don't have my LP with me right now but I think this list is correct.
