Page 9 of 20
Re: Sub 37 updated release date ?
Posted: Wed Jul 23, 2014 11:33 pm
by jsumners
It's going to be a loooong day at work tomorrow.
Posted: Thu Jul 24, 2014 1:31 am
by Voltor07
Sve wrote:Voltor07 wrote:The unboxing video is up! Check the Voltor's Videos thread.
Thanks, it was really all about the unboxing there
By the way, when you turn it on how long does it takes to warm up and become stable in its tuning?
Cheers
About 5 minutes.
Posted: Thu Jul 24, 2014 5:05 am
by egg
We need info Voltor!
Video would be nice but take your time and get something decent out. But what I would like is your immediate thoughts. How does it sound, does it give you the bumps?
Posted: Thu Jul 24, 2014 5:11 am
by Voltor07
egg wrote:We need info Voltor!
Sound wise it is similar to my Little Phatty. I haven't delved into it too deeply yet. I imagine it's capable of some pretty gritty stuff. I also own a Synthesizers.com modular, as well as the Taurus 3, but the Sub 37 is definitely a fierce competitor.
Posted: Thu Jul 24, 2014 5:50 am
by egg
Good stuff man.
I can't wait to get into those 2 mod sections and get weird.
Posted: Thu Jul 24, 2014 1:47 pm
by JonLukas
They have posted some documentation (though not the complete manual yet).
There is a MIDI implementation chart, and a menu reference.
http://www.moogmusic.com/products/phatt ... nloads-tab
This item in the menu reference made me smile:
LIGHT SHOW (GLOBAL MENU 2.4)
You can use this parameter to amuse your friends and confound your enemies. When set to ON, the front panel LEDs flash in a 1960s “futuristic” manner. While perfect for breaks between sets and television appearances, the default is OFF since you can’t see any of your button choices when it is animating. You can use the APREGGIATOR RATE knob to change the speed of the light show.
Posted: Thu Jul 24, 2014 2:24 pm
by _DemonDan_
JonLukas wrote:This item in the menu reference made me smile:
I was listening to Mozart's Confutatis Maledictis when I wrote it, so the phrase was on my mind.
Posted: Thu Jul 24, 2014 2:28 pm
by Bald Eagle
Looking at the menu reference it appears that poly chaining did not make it into the first cut. It says "this feature is not presently active" for the POLY NUMBER and POLYMAX parameters. I wonder when it will be available.
I guess the light show is more useful
Posted: Thu Jul 24, 2014 3:11 pm
by _DemonDan_
Posted: Thu Jul 24, 2014 3:26 pm
by Bald Eagle
I'm just whining because it will be some time before I can confound my enemies.
Posted: Thu Jul 24, 2014 3:30 pm
by _DemonDan_
I promise:
The very first time you hear the Filter and Amp EGs looping at audio speeds, you'll know it was worth the wait.
Posted: Thu Jul 24, 2014 3:43 pm
by monokit
They loop at audiorate? >1kHz?
Posted: Thu Jul 24, 2014 3:56 pm
by _DemonDan_
monokit wrote:They loop at audiorate? >1kHz?
I used audio rate to mean frequencies you can hear.
I don't have a measurement of it, but they can go from around once a minute up to a very fast buzzing sound.
I guess if I did the math...
If the Attack, Decay, and Release were each set at 1ms, then it should be able to do 333 loops in a second.
Shorter values would be even faster.
Posted: Thu Jul 24, 2014 5:07 pm
by monokit
I just wondered because i had a modular system, and the Make Noise Maths...a multipurpose module that can also be used as envelope generator goes into very high audio range, when looped...but what you just described is also already cool, esp. because Filter and amp env can be looped individually plus each of the env parts can also get modulated by the two LFO. Crazy!
Posted: Thu Jul 24, 2014 5:15 pm
by _DemonDan_
And... each of those Envelopes can also be independently SYNC'd to clock with any unit of the beat from 4 Whole Notes to 1/64th Triplets.
