Everything Phatty.
Benjaminam
Post
by Benjaminam » Fri May 06, 2011 12:29 pm
Amos wrote:
(a few minutes later) OK! All done. Also, I fixed the little "click" at the beginning of notes when volume sensitivity is high... it's much better now.
And the 15 levels of sensitivity (0 is off, 1-15 is increasing levels of sensitivity) is much better than 8. Thanks for asking about it!
Amos
I'm not sure if you are referring to the click that occurs when a soft note follows a very loud one, but if so, I'm am still experiencing this with the newest update. SE2.
LIttle Phatty SEII, Rogue, CP-251, Soldering iron
Assar
Post
by Assar » Fri May 06, 2011 1:23 pm
Amos wrote:Does it make sense the LP should only send clock out when the arp is running?
Or is it good/useful to send clock all the time?
I haven't read all the posts here, and I'm not an midi guru, so I may have missed something.
But wouldn't it be good to send it all the time, for example if you want to sync LFO with another LP/SP?
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
Assar
Post
by Assar » Fri May 06, 2011 1:25 pm
Amos wrote:TRIBUTE STUCK NOTES ARE FIXED!
Tribute beta release coming soon
My TE was shivering of anticipating ... I had to turn him off ...
Can I upgrade directly from OS 2.01T?
Amos
Post
by Amos » Fri May 06, 2011 1:29 pm
Assar: yes you can update directly from OS 2.x... TE update will of course only work on TE with EEPROM upgrade to run OS2. Won't work on original "stock" TE.
Benjaminam: I'll check again regarding the volume click. I may only be able to reduce it by so much; beyond that you'd need to increase the volume attack time to remove click (this generally works for any kind of click at the start of a note)
EDIT: All updates for all models of Phatty are here:
http://www.moogmusic.com/forum/viewtopi ... 228#p83228
dave500
Post
by dave500 » Sat May 07, 2011 10:59 pm
Thanks for the new OS... The install went smooth...
Model D, Little Phatty Tribute w/cv, The Rogue, MF-102, CP-251, Animoog and Filtatron
stromflut
Post
by stromflut » Wed Jun 01, 2011 10:00 am
I actually agree on having a LATCH-Button. I often play a note on the LP and play the guitar until i have to play the next note on the LP. Until now I try the best I can increasing the [Realease] to max, but the note fades out too soon... what else could i do?
thanks!
avj
Post
by avj » Thu Jun 02, 2011 9:35 am
stromflut wrote:I actually agree on having a LATCH-Button. I often play a note on the LP and play the guitar until i have to play the next note on the LP. Until now I try the best I can increasing the [Realease] to max, but the note fades out too soon... what else could i do?
thanks!
What I do is keep an 1/8" to 1/4" adapter plug around and keep it half-plugged into the CV GATE IN jack. For latching, I push the plug all the way in. You could use a latching footswitch or some other pedal to achieve the same result. I believe this is the intended purpose of the GATE jack, and having a LATCH hardware button or software function would be redundant.
joe_moog
Post
by joe_moog » Fri Jan 06, 2012 2:42 pm
Assar wrote:Amos wrote:Does it make sense the LP should only send clock out when the arp is running?
Amos (or anyone else),
Like Assar mentioned by way of example, I am trying to sync LFOs across 1 LP and 3 SPs, all in poly. Can I do this via MIDI clock?
Sub 37 • Voyager Select Whitewash/Lunar White • VX-351 • Little Phatty Stage II w/CV out • Slim Phatty (x3)
MF-101 • MF-102 • MF-104SD • MF-103 • CP-251 • MF-108M • MF-105M
Moog Pocket Protector
Sir Nose
Post
by Sir Nose » Fri Jan 06, 2012 2:50 pm
A sequencer restart command will retrigger the LFO.
joe_moog
Post
by joe_moog » Fri Jan 06, 2012 3:14 pm
What I am trying to do is have the LFOs from the Slim Phattys' respective voices stay in sync with the LP...
