http://www.moogmusic.com/news/sound-sou ... s-minitaur
quote
Minitaur filter cutoff frequency does not track at 100 percent but this can be adjusted using a hidden parameter......enabling all sorts of wonderful ...
does anyone know what hidden parameter Gordon Reid is referring too?
Minitaur cutoff frequency does not track at 100 percent
Re: Minitaur cutoff frequency does not track at 100 percent
David, the filter keyboard tracking is controllable via midi CC #20 - the default is approximately 50% according to the manual, but it can go from 0 - 200% Also, I haven't actually used the Minitaur's software editor yet, but I believe all the other 'hidden' parameters are accessible from there.
Cameron
"Information is not knowledge.
Knowledge is not wisdom.
Wisdom is not truth.
Truth is not beauty.
Beauty is not love.
Love is not music.
Music is THE BEST."
— Frank Zappa
Cameron
Beauty is not love.
Love is not music.
Music is THE BEST."
— Frank Zappa
They certainly are A good overview of the Minitaur editor in this video;artpunk wrote:I haven't actually used the Minitaur's software editor yet, but I believe all the other 'hidden' parameters are accessible from there.
http://www.youtube.com/watch?v=NLi9Gy95cPE
You can off course use any device capable of sending MIDI CC to do the same thing. So a MIDI controller or DAW can be set-up to control the Minitaur. I'm looking forward to getting my Minitaur & creating a Lemur template for it. That's going to be a blast with some of the objects available for templates
Hi David,David Bulog wrote:Minitaur filter cutoff frequency does not track at 100 percent but this can be adjusted using a hidden parameter...
Artpunk is quite right - sending a MIDI CC#20 <value> command will adjust the filter tracking of the MT. Note, however, that the filter tracking adjustment does not persist if you cycle the power.
- Greg
