Voyager is not analog, it is digital
aerophone
Post by aerophone » Fri Mar 25, 2011 8:26 am
Dear Voyager players,
I had that idea in my head for a long time - how can you store an analog preset in synth's digital memory when it is a position of knobs which, being analog, are nothing but resistance level...
So I took a screwdriver and checked - what a pity, Voyager is not analog, it is DIGITAL... A kind of AWM, sorry...
Mike
till
Re: Voyager is not analog, it is digital
Post by till » Sun Mar 27, 2011 8:07 am
Hello Mike,
when you open the Voyagers back and see its inside from the back side, you see the huge analog board with 50+ analog CV inputs at the right side.
(c) Till Kopper
The digital board on the left (partly burried under wide ribbon cables) scan the pots, switches, keyboard and the touch field by measuring the position. The convert this into a digital value for storage. This stored value (and not the sound generated) is then feed into an D/A converter to control the full analog oscillators, envelopes, filters, audio path. So the knobs are not straight attached to the sound generation. But the sound is created 100%analog.
The analog board uses CV for all parameters. Including each stage of the envelope, the mixer settings (via VCAs). So the analog board got some analog functions not even available as CV on the Moog modular. For example the 4 stages of the envelopes. So the technical break through was the complex analog board for the Voyager.
So before posting your "what a pity, Voyager is not analog, it is DIGITAL", please learn what is digital and what analog in the Voyager. Just the patch memory and the midi is digital. The sound is 100% generated and controlled analog.
(Edit: typo in last sentence: 10% meant of cause 100%)
Just Me
Post by Just Me » Sun Mar 27, 2011 3:23 pm
Does this mean if my telephone has pushbuttons, it is digital and not analog like my rotary dial?
There is digital in the MIDI Interfaceand the Quantizer of my Modular synth. Does that mean it isn't an analog synth?
CZ Rider
Post by CZ Rider » Sun Mar 27, 2011 4:16 pm
Back in the day, we called something like a Voyager a "Hybrid" synthesizer. A mix of both digital and analog. It seems today poeple call a hybrid with an all analog audio signal path an analog synthesizer. I find that interesting, as if saying it has anything digital is bad, so they put the analog tag on it. It is important to know what you are playing and what control you have over what you are playing, no?.
I always thought of the Voyager as more of a hybrid and the Voyager Old School for those that wanted analog control.
till
Post by till » Sun Mar 27, 2011 4:36 pm
If the definition of analog is that strict, then there are no analog synths with midi ever possible. And only the CS80 like approch for storing patches would be analog at all.
And the Voyager OS has also some non analog parts inside. The keyboard action from Fatar can't produce analog voltage to feed the oscillators. There is some logic involved to get the key numbers being pressed and to generate the CV to control the synth part. The old Moogs used to have a full analog keyboard action based on voltage dividing by fixed resistors and a simple gate contact to generate the trigger and the gate for the envelopes.
LivePsy
Post by LivePsy » Sun Mar 27, 2011 7:39 pm
The Voyager Old School would not be fully analog if you used a digital camera to take a pic of the front panel for patch storage. You would have to use a film camera and take it to a drug store for prints. This is the seriousness of arguing anything digital must be bad. Digital is excellent at keyboard scanning, patch storage and communicating between devices (MIDI's limitations are due to its age, not just being digital).
Any manufacturer would be stupid not to use the best technology available. That includes Moog.
I've stopped talking now.
CZ Rider
Post by CZ Rider » Sun Mar 27, 2011 8:20 pm
till wrote:If the definition of analog is that strict, then there are no analog synths with midi ever possible.
Well, sort of? MIDI is an acronym for Musical Instument Digital Interface. How is a digital interface not digital?
It just strikes me as funny that no one seems to want to admit that there is digital circuitry inside something like a Voyager or any other modern digital-analog hybrid synthesizer.
Back in the 70's, manufactures were proud to announce their synthesizer used digital technology. The Prophet V stated right in the manual " The term Digital-Analog Hybrid is often used to describe the Prophet". But today the term "Pure Analog" would be used to describe a Prophet V. One would have to ignore the Computer Board inside with it's CPU and digital components. You knew there were trade offs with this type technology, like the steppeng when turning a knob that was digitally scanned. This is why today people get dissapointed with a hybrid, when they hear the artifacts of the digital scanned controllers. And there are quite a few people that believe a hybrid is pure analog, when it is not.
As a player it is important to me not to expect a scanned controller to act the same as an analog device. A MIDI mod wheel versus an analog one is a good example where I will use each one in a different way. It's good to know where, why, and how things work on your instrument, and apply that to your playing style.
So for the OP, of course the Voyager is a hybrid of both digital and analog. How else would it work?
c7sus
Post by c7sus » Sun Mar 27, 2011 10:00 pm
I don't see anybody denying there are digital components to the Voyager design.
But as Till pointed out, the sound engine is 100% analog. As in no digital oscillators or filters.
The OP makes it sound like he was expecting vacuum tubes and a crystal set when he opened his Voyager.
magnet
Re: Voyager is analog, it is also digital
Post by magnet » Mon Mar 28, 2011 9:23 am
My 2005 Voyager was making some really strange sounds, so I opened it up to take a look. Turns out I had to order a replacement tube set from Moog. But it still makes strange sounds... :)
Voyager PE/ Frostwave Fatcontroller Seq./ Korg Dw-8000/Little Phatty Tribute #188/Korg EX-8000/KP3-Kaoss Pad/ EH Deluxe Memory Man delay effect/Peavy KB-100 amp
Unfiltered
Post by Unfiltered » Sat Apr 02, 2011 5:49 am
That's like saying a guitar is not acoustic if it has "pickup" written in the metal used to make pickups where the pickups normally would be if the guitar itself was the opposite, i.e. the words "acoustic guitar" written in the wood that the guitar is made of in the pickup's normal position, even if it was an electric guitar!
The bottom line is that the words acoustic, organic, electric, electronic, digital, and analog, discrete and integrated can all be used loosely. I saw an all "acoustic" concert where the bass player was playing a hofner beatle bass. There are things called digital microphones now, how is that possible? Is a guitar with active pickups technically an electronic instrument?
Fordy
Post by Fordy » Mon Apr 18, 2011 3:43 pm
If the signal path from the oscillators to the outputs is all analog then it's analog, no two ways about it!
Kind Regards
-Fordy
Gear: Nord Wave, Access Virus TI 2 Keyboard, Moog Voyager Select, Korg Radias, Novation Supernova II, Quasimidi Polymorph, Korg Electribe SX, Eminent 310U,
FX: EH Stereo Small Stone Phaser, EH Stereo Electric Mistress, Lex MX400.
MC
Post by MC » Mon Apr 18, 2011 6:12 pm
Fordy wrote:If the signal path from the oscillators to the outputs is all analog then it's analog, no two ways about it!
Thus endeth the thread
Post by EricK » Wed Apr 20, 2011 2:44 am
Analog Caller ID
psicolor
Post by psicolor » Sun May 01, 2011 6:16 pm
till wrote:The analog board uses CV for all parameters. Including each stage of the envelope, the mixer settings (via VCAs). So the analog board got some analog functions not even available as CV on the Moog modular. For example the 4 stages of the envelopes.
then a vx352 with cv inputs for everything would make the voyager a perfect hybrid modular/compact synthesizer
http://www.psicolor.de
