hi,i want to know if the new moog taurus 3 bass pedal can be put in quik lok stands,
quik lok-ql-400 or quik lok ql-402
J
Moog Taurus 3 Stand
- superd2112
Re: Moog Taurus 3 Stand
Hello, & welcome to the forum! It looks like the T3s would fit in the QL-402, but playing them on the stand could prove problematic. Also, the side located outputs might be partially blocked by the stand. Are you planning on using the Taurus as a MIDI module, maybe in a studio setup?EmptyJ wrote:hi,i want to know if the new moog taurus 3 bass pedal can be put in quik lok stands,
J
Moog Taurus 3 Stand
Hi&Thanks,
no i dont gone use at as a midi module,in a studio set up yes and it will be better to me that it sit on a stand&high,so the quik lok-ql 402 will be good,you have another stands like this one that will be good for me
Thanks Much
J
Thanks Much
J
- superd2112
I don't know - weight-wise, the Taurus 3 is a pretty beefy synth (no pun intended), and it may be safer to simply play it on top of a table to prevent it from accidently falling to the floor. Sturdy as it is, I don't think it would survive a 5-foot fall.EmptyJ wrote:Hi&Thanks,
Thanks Much
J
That might be difficult putting a Taurus unit on a stand because of the foot pedals. You might go with a tabletop stand designed for electric pianos like Rhodes. Those are about 70 bucks.
Now are you wanting them to be inside the bottom of a stand on the floor?
This is the dilema for those uf us who own Voyagers or Phattys or any other narrow synth on a stand, is how to properly sit at the voyager and have the pedals situated for proper playing posture/ technique.
Im currently trying to figure this one out myself. I almost won a polymoog auction, and that would have solved my problem.
- superd2112
taurus 3 stand
you have more stands options to me,i dont want the taurus 3 to be on the floor or to put at on a table that it take much space of my room,the quik lok ql-402 will be good but i just saw that in wide(27 inch) is ok and in the deep is not good the taurus 3 is 24 inch&stand just max 16 inch,so help to find a good stand that not take much space
Re: taurus 3 stand
Would a Z-stand work for you? A two tier, perhaps? Quik-Lok makes some very nice stands, but the weight and odd shape of the Taurus III makes it difficult to find something suitable to put it on. This is indeed a conundrum.EmptyJ wrote:you have more stands options to me,i dont want the taurus 3 to be on the floor or to put at on a table that it take much space of my room,the quik lok ql-402 will be good but i just saw that in wide(27 inch) is ok and in the deep is not good the taurus 3 is 24 inch&stand just max 16 inch,so help to find a good stand that not take much space
I think the first thing to consider is that, whatever stand you go with, you will probably want to put mount the T3 on top of a 25" X 24" X 3/4" plywood board on the stand, since the T3 is made to sit on a flat surface. Paint the board black, and no one will know the difference.
After that, choose whichever stand will accommodate the board. You could go with a Quik Loc WS-550, if you don't need to roll it around. Or, you could try the Quik Loc ZM/20 legs with the ZM/25 or ZM/34 crossbar, and then add the ZM/99 caster kit (wheels).
I hope that this helps you.
Yeah I got to thinking, and without a shelf like that, theres no way that the Taurus would go on a stand like that. Because of the nature of the way these are played, and the shape of the unit, the rubber foot placement being where they are, onw would have to perfectly situation the unit on a stand and theres no room for error before ones taurus is on the floor.
There ain't going to be any bull wrastling in my studio.
I would also recommend forgetting about using the Quik Lok QL-402 as, due to the weight of the T3 (45 lbs.) and the rather small diameter of the wheel base, it would be way too easy to tip over, and you would not be able to prevent it from happening if it started to go, as the wheels would just cause the base to slide out from under it as soon as you grabbed the top part of the stand to keep it from going over.
If you need to mount the T3 on a stand, don't cheap out, go for the most stable and sturdy stand that you can afford.
