Hello!
When I first mentioned Switced on Bach, it was a Wendy Carlos reference. My really favourite albums ore The Beauty in the Beast and Sonic Seasonings...
Just so you all know.
TRON
Beginnings
You will need to set the preferences under File. You need to get your sound card as the audio out. If you have a typical sound card, there might be some latency: a delay in hearing your sound after hitting a key. A sound card with an ASIO driver will improve things quite a bit. You may need to redirect on the IN and Out which is located on the top of the softsynth's main panel.
I use the Moog Modular V2. It's a very good softsynth and will give you the basic understanding of working with a modular. I have used it frequently in live performance. The written manual that comes with the purchased softsynth is quite informative.
Mark Mahoney
www.cdbaby.com/cd/markmahoney
To get the Arturia Moog Modular to make a sound you have to right-click on the VCA gain knob and select the keyboard as your input or something like that -- can't remember exactly offhand. I can check if you're still stuck. Although I think the presets should be wired to make a sound right off the bat...
I'd first try:
ASIO
Yamaha PCI Audio
44100
Linear (this is not essential at this stage. It's for moving virtual knobs)
If this doesn't work, try the other settings. I am assuming your audio card is the Yamaha.
ASIO
Yamaha PCI Audio
44100
Mark Mahoney
Hello!
No way to make it work, after playing 4 notes it saturates the processor and though the task manager says the application is running it seems frozen... oh! and I can't see the keyboard anymore. I must say however that the graphics are superb!
Is there anything a little friendlier out there?
Thanks for your efforts!
This ia a very friendly forum, or at least it's members are!
TRON
TRON
