Post
by RichardK » Mon Jan 12, 2009 4:16 pm
For someone working in Logic with soft synths
For someone not overly attached to modern or old-school kit
For someone who wants an analogue sound...
Access Virus Ti.
It's not analogue, but there's something about the modeling that "feels" more analogue than, say, the SuperNova. It'll integrate with the studio layout nicely, and there's a choice of 61 or 37 key models.
I've got the older version, the Indigo 2; I had to have one after hearing a Virus b desktop.
FWIW, I have owned a Juno 6 and a Roland JX10, the SuperJX was a limited, annoying device to work with and really quite soul-less - I would consider a Roland JD800 (or, since you've got that SR-JV card kicking about, a rackmount JD990) a better bet, but even then I went over to a newer XV since I never really got into programming the JD.
Your Triton will do the pads well. The SE is the fun monosynth IIRC? The Lead does some nice glitchy stuff and some weirder sounds. An Access Virus would give you the fat, analogue-feeling sounds and 80-voice polyphony (max, of course, it's really more like 32 apparently) plus easy access from the sequencer.
I also tried the Prophet '08, but the shop hadn't set it up with stereo outputs and as such, I didn't get into it.
Access have incorporated a model of the Moog filter. I have no idea if it's really accurate, but the synth IS impressive.
FWIW, I'm using my Voyager with a t.c. electronics FireworX. THAT can make some pretty screwed-up sounds...
Some things hurt more than cars & girls
Sound: Voyager PE, VX-351, CP-251; AIRA, MiniNova, Karma, Reason, Maschine, OP-1
Control: Zaquencer, Reason, Panorama P4
