There could be a hardware solution - the question is, can there be a practical hardware solution which is not too expensive?dagargo wrote:Amos, do you think is there a hardware solution for this?
The most effective hardware solutions I can think of will involve an additional circuit board, and possibly a need to cut traces and solder wires to mate the new circuit board to the existing boards inside the TE.
The best solution must not require too much modification to the original electronics, or too much skilled labour necessary to install the mod. So, this is an engineering challenge. I assure you that I am working on this and will not let it be forgotten.
However, Moog Music is working on a lot of very interesting new products for 2008, and we still have only the same small engineering staff... so we must be patient. The engineers must balance many projects at once, so it could be some time before this LP TE noise project can be completed.
-Amos
