Hehe, guilty as charged. For someone very determined to be all analog with his synth, I'm letting a digital sequencer play all the notes for me. Yes I'm more of a tweaker than a keyboardist, but I'm a very proficient tweaker. I almost never use presets - I generate nearly all my sounds from scratch. This is because I have in my head the kind of sound I want, and it's much, much faster coming up with it by creating it than searching around for a patch that sounds similar. As a result of learning how to program sounds, I have gained a great deal of appreciation for subtleties. So yes, I'm very, very picky about the sounds I create. And I love the silky smooth texture of real analog.Amos wrote:A lot of people now let MIDI play all the notes, while they use both hands to change the sound.
Why'd you do it ?
- RL
I wanted a small studio with minimal equipment. Since I am an analogue synthhead I wanted a Moog. However, I didn't want to invest lots of money in old machines that suddenly can break down.
So I decided to buy a Moog Little Phatty. To be able to save patches, get new components, a brand new synth and built in midi made me drool.
It was also small, looked nice and gave me those sweet leads and the fat basses that my MS20 was to harsh to offer. In other words - a great companion to my old friend. The Voyager looks and sounds great but was way out of my budget.
Well, this might be true, but I hope you will not start to design your synths for these people only. The great thing about a Moog synthesizer is that you can play it as an expressive instrument: one hand on the keyboard, the other on the wheels or knobs ... who needs MIDI?Amos wrote:A lot of people now let MIDI play all the notes, while they use both hands to change the sound.
People like me doing electronic dance music where everything needs strict clockwork timing. And if it weren't for midi, the Voyager wouldn't be having those zippering issues. It would be straight analog. I wouldn't have a problem with that. In fact I would be extremely tempted to save up to buy one if it had analog controls.doctorno wrote:Well, this might be true, but I hope you will not start to design your synths for these people only. The great thing about a Moog synthesizer is that you can play it as an expressive instrument: one hand on the keyboard, the other on the wheels or knobs ... who needs MIDI?Amos wrote:A lot of people now let MIDI play all the notes, while they use both hands to change the sound.
Even if you do play notes manually: say you have a sustain pedal and want to manipulate two parameters while holding a note. True analog sound is best only when everything from the controls to the sound engine is analog.
Rudi, would this allow two pots tweaked at one time without glitching? If so it is a great idea!RL wrote:OK, what do you think about that idea?
When the display parameters is "on/3sec" only one pot is active to avoid crazy display flickering. When the display parameters is "off" all turned pots stay active unless the user changes a preset.
Rudi
How would this be possible? Cutoff and Resonance are modified by the same pot, and you select either cutoff or resonance with the push buttons. So you can never modify them simultaneously.Amos wrote: I can change cutoff and resonance independently at the same time with only one hand... put thumb on Resonance, and first two fingers on cutoff... then you still have one hand to play keys!
Jack
Sorry, I was talking about the Voyager here... this was a sort of side-discussion about zipper noise on the Voyager when too many pots are turned at once.Funkasizer wrote:How would this be possible? Cutoff and Resonance are modified by the same pot, and you select either cutoff or resonance with the push buttons. So you can never modify them simultaneously.Amos wrote: I can change cutoff and resonance independently at the same time with only one hand... put thumb on Resonance, and first two fingers on cutoff... then you still have one hand to play keys!
Jack
You can set up the LP to tweak cutoff and resonance at the same time... use Pot Mapping to assign one of the other pots to control resonance, and use the Filter pot to control cutoff. If you do this, then you will have RAC on the cutoff but not on resonance... but that is OK as RAC is not as crucial when changing resonance (amplitude at cutoff frequency) than it is for cutoff.
