I wish I had known this place existed.Quick question
So im new to moogs amd I have a fooger phaser.Has anyone seen the little boxes that were selling on ebay as fooger controllers? It was basically a box, a jack, and a switch. It allows you to have the setting on the moog and then when you hit the switch on the box(plugged into a c.v. input) it changed the knob value to that of the box. How could I make one of these. Also whats the going rate for a 104sd?
I'm no expert but here is a thought: can't you build one pretty easy? The manuals show how to wire a potentiometer; it sounds like you basically want a toggle switch added in-line...
I ordered a 104z; I think the 104sd is going to be very hard to find and expensive!
I'm looking for a simple diagram and parts list for a Mult circuit by the way! Good luck!
