Hi all!
New member here (but long time lurker)
I have bought a moog E1 for at great price, but it's missing it's control pedal, 5-pin cable and power supply...
Now where the hell do I find that?
I have thought about building the missing parts. I have a very skilled electrical engineer on hand, so making a box that distributes the power is doable, but what is the specs of the power supply and the 5-pin cable?
- Simon
What expression pedal, cable and supply do I need?
Re: What expression pedal, cable and supply do I need?
Wondering this myself – in particular, when buying a new cable for the guitar, how should it be rated?
I have the original guitar cable and pedal, but no specs unfortunately, not sure how to help you – maybe I could make some measurements that would be useful? I have a multimeter on hand.
I hear you on the missing specs! For the control pedal, the Moog EP-3 is a great choice, and you can use a standard 5 pin MIDI cable for connection. For the power supply, look for a +12V DC supply with at least 500mA. If you’re unsure about the pedal specs, a multimeter can help measure the resistance or current draw. That’ll make it easier to match the right gear.
i choose the Dunlop DVP4 expression pedal, paired with a Mogami 1/4" TRS cable and a One Spot 9V DC power supply for a reliable setup. papa's games
